Activity › Forums › Adobe After Effects Expressions › Switch between a number of layers with slider control
  • Switch between a number of layers with slider control
    Posted by Moog Gravett on April 5, 2016 at 2:08 pm
    Hi folks,
    hope someone can help me here.
    I want to partially automate some layer switching but can only find how to do it between two layers thus far.
    I want to have, lets say 5 (but ideally scaleable) layers that I can switch on and off with a 1-5 value on a slider control. Or some other animatable solution of course.
    Any ideas?
    Cheers,
    Moog
    Moog Gravett replied 10 years, 5 months ago 3 Members · 4 Replies
  • Jakob Wagner
    April 5, 2016 at 2:36 pm
    Hi
    1. Create the five layers. 😉
    2. Create a null and rename it to “control”.
    3. Create a expression control slider on the null.
    4. Rename the slider to “Turnus”.
    5. Insert this code in the Opacity property in all the five layers:
    var totalLayers = 5;
    var layerIndex = 0;
    var visible = thisComp.layer("control").effect("Turnus")("Slider")>100/totalLayers*layerIndex;
    opacity = visible?100:0;
    6. Layer index on the first layer is 0. Next layer is 1, etc..
    Drag/animate the slider from 0 to 100.
    Hope it helps.
    – Jakob Wagner
  • Moog Gravett
    April 5, 2016 at 3:12 pm
    Hi Jakob,
    Thanks very much for your quick reply.
    I gave it a try but as I have it at the moment, the layers aren’t switching, rather it stays on one layer (the one highlighted in the screen grab). Would you mind taking a look to see what I’m doing wrong?
    Cheers,
  • Miguel De mendoza
    April 5, 2016 at 4:11 pm
    Maybe this ocurs because the slider have coma values(1.3, 2.7)and when interpolating cant find a 1.3 layer. So you can try to floor the slider value, to make this code work you only have to add to your layers name an index sufix “_1”, “_2”, etc…:
    sliderValue = //Your link to the slider
    nameSplit = name.split("_"); //
    shapeNum = nameSplit[nameSplit.length - 1];
    if (shapeNum == Math.floor(sliderValue)) {
    value = 100;
    } else {
    value = 0;
  • Moog Gravett
    April 5, 2016 at 4:34 pm
    Brilliant!
    Thanks Miguel, that did the job beautifully.
    All the best and thanks to you both for taking the time to help.
    Moog
