Activity Forums Adobe After Effects Swirls and Twirls effect in After Effects?
  • Swirls and Twirls effect in After Effects?
    Posted by Chris Mathews on August 22, 2015 at 12:00 pm
    Hi, I would like to ask you if you know how those twirls were made in After Effects, i want to recreate them identically.
    In the video they’re above the christmas tree. The video is created in December 2006, so must be something easy, but i cant get it.
    https://youtu.be/x0uGYh-sfQA
    Chris Mathews replied 11 years ago 2 Members · 6 Replies
  • Kalleheikki Kannisto
    August 22, 2015 at 7:08 pm
    A particle system such as CC particle world with the emitter animated in that manner.
  • Chris Mathews
    August 22, 2015 at 7:24 pm
    Can you please tell me how? I know the Cc particle world is used only for particles, not helix twisting
    August 22, 2015 at 7:29 pm
    The emitter would be parented (with some horizontal distance between them) to a null that both rises and rotates along y-axis. The emitter emits particles as it goes. This creates a helix shape.
    You can also animate the distance between the emitter and the null to get a tapering helix, etc.
  • Chris Mathews
    August 23, 2015 at 1:09 am
    Can you please make a sample file, I was trying and no luck, It doesnt work, I want the same look 🙁
    August 24, 2015 at 6:36 am
    Hi Milos,
    I forgot you can’t directly connect Particle World to a null, so I did the twirl with expressions. I can’t tell from the video what it is meant to look like, but this should get you started. Modify the expressions and other settings to taste.
    9173_particleswirl.aep.zip
  • Chris Mathews
    August 25, 2015 at 4:34 pm
    Thanks for the effort, but this is not what i was looking for. I ended up with a solution of custom made paths to be followed by the Particular to clone the exact same effect.
