Activity Forums Apple Final Cut Pro Legacy “swapping” timeline edits…
  • “swapping” timeline edits…
    Posted by Donna Valenti on January 29, 2010 at 5:06 am
    has anyone else experienced this – you swap clips on your timelne, no problem. then you attempt to make clip number three – or any clip, really, at the end of the timeline – instead of it making a regular swap, it puts on the end, but keeps it in it’s original position as well… is this a bug in final cut, or is there a keystroke that comes into play when you are swapping to the end of your timeline that i don’t know about??? thanks!
    ~DV
    Donna Valenti replied 16 years, 8 months ago 2 Members · 2 Replies
  • Shane Ross
    January 29, 2010 at 6:37 pm
    Are you holding down the OPT key when you do this? Depending on the type of arrow you get when you swap, different things happen. A curved arrow swaps the shot, an arrow pointing to the right (downstream) will COPY the shot. make sure you have the curved arrow pointing down.
    Shane
  • Donna Valenti
    January 29, 2010 at 8:59 pm
    thanks shane- working on a 17″ macbook – can’t always see the icons as clearly as i would like to…didn’t realize the incorrect icon was active… little things i’m not quite used to with final cut yet…
    ~DV
