Activity › Forums › Adobe After Effects › Swapping Multiple Layers
  • Swapping Multiple Layers
    Posted by Ed Hecht on October 13, 2011 at 12:52 am
    I have a project (with a master comp) with over 100 instances of the same (sub-)comp that needs to be replaced en masse. In Windows, is there some variation of the Alt+Shift method to swap multiple layers at once? Shouldn’t I be able to choose six comps from the Project pane and Alt+Shift drag into six highlighted comps in the Timeline?
    Michael Szalapski replied 14 years, 11 months ago 2 Members · 2 Replies
  • Michael Szalapski
    October 18, 2011 at 7:21 pm
    One thought is to simply place the new comp inside the old comp and delete anything else in the old comp.
    – The Great Szalam
    (The ‘Great’ stands for ‘Not So Great, in fact, Extremely Humble’)
  • Michael Szalapski
    October 18, 2011 at 7:22 pm
    Now, you may be able to alt-drag comps from your project window onto highlighted ones in the timeline. I know you can do one at a time…
    – The Great Szalam
