Activity Forums VEGAS Pro SVP 11 – Rendered Sony AVC/MP4 file – audio seems to sit just slightly behind video?
  • SVP 11 – Rendered Sony AVC/MP4 file – audio seems to sit just slightly behind video?
    Posted by Rikki Daman on July 31, 2012 at 12:48 am
    Just output my first render on my new PC with SVP 11 and found a problem…
    https://youtu.be/11g_iWzsAkM?hd=1&t=4m44s
    The white flash should sync perfectly with the beat of the music kicking in.
    It does on the timeline in Vegas, and when I preview inside Vegas but the MP4 file it outputs is identical to the YouTube upload, the video runs a fraction of a second earlier than the audio.
    Is this a known fault and is there an offset I can enter or will I just have to manually nudge my audio tracks under SVP11 compared to 8 ?
    Thanks folks 🙂
    Rik
    Rikki Daman replied 14 years ago 2 Members · 6 Replies
  • Michael Acres
    July 31, 2012 at 2:48 am
    i got over a minute into this video and didnt see any white flashs…maybe im just blind.
    But to answer your questions I havent experienced what your talking about.
  • Rikki Daman
    July 31, 2012 at 5:27 am
    Hi there,
    4.40 would be an example – I did put the link in the YouTube URL but this forum software stripped it out – doh!
    R
  • Michael Acres
    July 31, 2012 at 6:37 am
    i didnt see a white flash at 4:40 so i guess you meant 4:46
    try rendering to mpeg2 or xdcam and see if the problem repeats.
    also you didnt mention what output setting you used but again i had to assume you used mainconcept avc mp4
  • Rikki Daman
    July 31, 2012 at 8:37 am
    Re: SVP 11 – Rendered Sony AVC/MP4 file
    Its all in the title 😉
    I’ll give another encoder a shot later, dont really want to use something else as Mainconcept is dog shit, especially with GPU rendering enabled it looks like crap.
    Will give it all a go later tho. In the meantime a workaround (dont we love Vegas and its work arounds) is to make project, grab audio and move it backwards 2 frames
  • Michael Acres
    July 31, 2012 at 9:20 am
    you could also take the outputed mp4 back into SVP and see if the audio peaks synch properly with the rendered video (as compared to the project audio peaks)
  • Rikki Daman
    August 15, 2012 at 12:04 pm
    It seems to be out a touch too.
    What I found last night was the sync on YouTube drifts out more and more depending on how long the video is :S
    https://youtu.be/D8sQdSoP_m0?hd=1&t=12m6s
    Thats at 12 minutes.
    EDIT: add the ?hd=1&t=12m6s to end of link
