Activity Forums VEGAS Pro SV MSP 13 Preview Not Working with External Monitor
  • SV MSP 13 Preview Not Working with External Monitor
    Posted by Mike Kerr on March 20, 2016 at 12:04 pm
    I am able with no problem to do a Preview of a project to the preview window within the Vegas GUI. Not a problem there.
    When I click the external monitor, the GUI preview goes black, and the preview monitor shows the first still frame of the project. When I play, I hear audio, but nothing changes in the GUI or the monitor displays. If I play without the external monitor, it works fine, and if I click the external monitor while its playing, both the GUI and the external monitor go black.
    I have messed around with the Preferences for Preview Device and everything appears ok. Settings there have these options checked: Scale Output, Adjust Levels, Optimize GPU. All else is default. In Preferences -> Video everything is default except GPU Acceleration is set to AMD (Hawaii) – though truth be told I doubt this would have any effect whatsoever since I have an R9 390x.
    I do not recall if I installed the video drivers for the 390x before or after I installed Vegas (pretty sure it was before).
    I am running Windows 10, have a Sapphire R9 390x hooked up to 2 monitors, and am running the last beta driver for AMD Catalyst from December. I am unable to get the new Crimson drivers to install. Prior to upgrading to Windows 10 from 8.1, external monitor was running fine, and drivers I was using were like nearly a year out of date.
    Have thought about reinstalling Vegas, but it’s been such a pain to get it back to where it was before I upgraded, I’m loathe to put myself through that again if I can avoid it.
    John Rofrano replied 10 years, 5 months ago 2 Members · 3 Replies
  • John Rofrano
    March 20, 2016 at 12:18 pm
    If you upgraded in place from Windows 8.1 to Windows 10 this could be your problem. I would never upgrade a Windows system in place. Always build a new system from freshly formatted disks. I don’t use Windows 10 so I really can’t help debug this but I have read about several Vegas Pro editors who upgraded Windows 10 in place and had all sorts of problems, and then did a clean install and everything worked. …just passing along the info.
    ~jr
    http://www.johnrofrano.com
    http://www.vasstsoftware.com
  • Mike Kerr
    March 20, 2016 at 3:42 pm
    Yeah I’d heard a lot of problems upgrading in place as well, which is why I did a clean install of Windows 10, so the whole kit and kaboodle is a clean install.
  • John Rofrano
    March 21, 2016 at 1:01 pm
    Hmmm… that is odd then. Sounds like a graphics driver problem to me. You said you were using a beta driver. I would go back to an older stable driver.
    ~jr
