Activity Forums Adobe After Effects suretarget(AE) and trapcode
  • suretarget(AE) and trapcode
    Posted by Martin Weterholt on December 23, 2009 at 11:22 pm
    Hello all,
    I’ve got a problem that i need your help with. I’m going to explain it as clear as i can.
    I have made a composition with a camera and about 13 text(3d layers). These layers are followed with suretarget. That’s working fine.
    Now i want a nice 3d stroke under the 3d text. But when i make a new solid, make a line and then apply the 3d stroke, it doesn’t work.
    i only see my written line.
    I’ve tried the following:
    – use comp camera
    – use a preset
    – create a new solid
    nothing works. How can i apply the 3d stroke to my camera so i can see the created stroke and how do i make it move with my suretarget presets.
    Martin Weterholt replied 16 years, 8 months ago 2 Members · 3 Replies
  • Travis Howle
    December 25, 2009 at 4:34 pm
    Have you tried to make the solid, and use the 3D Stroke from Trapcode, with a mask, and then change the start/end over time to follow the movement with the camera?
    I don’t have AE in front of me right now, but that is how I did it to make the effect work a while back.. if I am understanding what you’re asking.
    Hope it helps!
    Merry Christmas
  • Martin Weterholt
    December 26, 2009 at 11:54 am
    can you tell me how to do thius exactly, not quite sure if i’m doing it correctly..
  • Martin Weterholt
    January 4, 2010 at 11:04 am
    anyone?
