Activity Forums Adobe After Effects suppressing specific colors WITHOUT using hue-sat control
  • Michael Szalapski
    August 17, 2011 at 8:14 pm
    Using the Hue/Sat control, you can isolate certain colors to desaturate. Poke around in it some more. (Specifically the channel control. Note that you can adjust it further beyond the basic drop down.)
    That being said, you could also key them out and use the key as a track matte for an adjustment layer (among many other ways to control it).
    Also, check out Synthetic Aperture’s Color Finesse that comes with AE. It has a ton of very powerful color grading tools in it.
    – The Great Szalam
    (The ‘Great’ stands for ‘Not So Great, in fact, Extremely Humble’)
  • Kevin Reiner
    August 18, 2011 at 9:15 pm
    Change To Color and Change Color are good for a quick fix. Then I second Michael’s suggestion of Color Finesse. You can also get somewhere with curves. Depends on what you’re trying to accomplish.
    Mac Pro 2 x 3 GHz 6-Core Intel Xeon
    32GB Memory
    Dual-channel 4Gb Fibre Channel PCI Express card
    Dell Display (23″ flat panel)
    ATI Radeon HD 5770
    AJA Kona LSi SD/HD capture card
    Rourke 16 TB
    Flanders 2460
    SOFTWARE
    Mac OS X 10.6.5
    FCP 7
    After Effects CS5
    Boris Continuum
    Sapphire Plug Ins
    All Trapcode Plugs
    Zaxwerks Invig
