Activity Forums Apple Final Cut Pro Legacy Super8 Film capture – DV progressive/interlace? 24/25fps?
  • Super8 Film capture – DV progressive/interlace? 24/25fps?
    Posted by Paul Stroud on January 19, 2011 at 11:49 pm
    Guys – I’m stumped
    I shot onto Super8 for a music video… it was sent off to be digitized and came back on DV tape
    Now I may have captured at the wrong frame rate and with the wrong interlace/progressive settings
    Because i’m a little in the dark regarding video formats, interlacing vs progressive (although I understand the concept), PAR etc… I may have made a slight error… I think because I’ve told FC that I’m capturing DVPAL footage it’s decided that the timebase would be 25 fps and it would be interlaced
    IS THIS WRONG?
    I tried changing sequence settings “field dominance” to NONE, which was fine – no combing – better image. However, I had to clean a couple of interior shots with RG denoiser – now it refuses to work unless I set field dominance to lower. Even with re-applying
    Any thoughts people?
    Many thanks
    Jeff Mueller replied 15 years, 8 months ago 2 Members · 2 Replies
