Activity Forums Apple Final Cut Pro Legacy super slow rendering
  • super slow rendering
    Posted by Gus Mann on May 28, 2008 at 1:44 am
    i am running a Quad G5 power Mac with 12 gigs of RAM… running FCP 6.0.3 in Leopard..
    For some reason my computer is rendering reallllly slow…. what would take about a minute to render 30seconds is now taking nearly 8 min…
    does anybody know if there is a compatibility issue with Leopard and FCP???
    Im super frustrated…
    thank you for any help i can get
    Gus Mann replied 18 years, 3 months ago 2 Members · 2 Replies
  • Zane Barker
    May 28, 2008 at 3:30 am
    Well first off FCP can only use 4 GB or Ram. Anything more then that helps with the system & running other applications at the same time.
    If you could give up some more info we may be able to provide a more complete answer.
    What format video are you working with?
    What are you using for your media drive?
    How full is that hard drive?
    Did you just recently move to Leopard?
    If so did you do a clean install or run it as an upgrade?
    There are no “technical solutions” to your “artistic problems”.
    Don’t let technology get in the way of your creativity!
  • Gus Mann
    May 28, 2008 at 4:54 pm
    thank you for the quick reply….
    all my work is in SD format which i render down in either intermediate codec or 422 hi-rez….
    my harddrive i have my info on is actually pretty full but i still have 100 gigs left out of 750….
    I have been using leopard since it came out and it was a clean install…. i got rid of everything…. i did a clean install of my FCP suite and my other software….
    i have been reading other forums and threads on this issue and one of the solutions was to make sure in my User Prefs / Render Control … i should keep the quality at Normal and to keep the “Always Use Best Quality When Rendering Movies” unchecked……
    i did exactly that…but still i have the same slow rendering…. i’ve tried different codecs and still the same thing..
    im pretty confused and frustrated..
    thank you for any help you can give me..
