Activity › Forums › Apple Final Cut Pro Legacy › Super 16 aspect ratio in FCP 5
  • Super 16 aspect ratio in FCP 5
    Posted by Y12video on May 17, 2006 at 10:48 am
    Hey guys,
    I’ve just gotten some super 16 film transferred to DVcam and captured it. I have a problem I can’t figure out. In the viewer window, the footage shows up letterboxed like it should be, but when I drag it into the sequence it is squeezed horizontally. The sequence has the same settings as the footage that I captured. I’ve tried making changes like clicking the anamorphic box, but it makes the frame too large. I shot some video (DVcam) on 16:9 mode, and it looks fine. The frame goes all the way outside of the 10% box to the edge of the frame. Am I doing something wrong, or could it be something in the film transfer that was done wrong?
    Thanks.
    Y12video replied 20 years, 4 months ago 2 Members · 2 Replies
  • Jerry Hofmann
    May 17, 2006 at 1:20 pm
    Sounds like the transfer is standard 4:3… and the letterbox was part of the transfer (pretty common). If so then, you should be using just the standard DV NTSC sequence preset.
    Jerry
  • Y12video
    May 17, 2006 at 6:13 pm
    Booyah! You hit the nail on the head. Thanks, problem solved.
