sum up all the values of the frames before
hello,
i’ve got a really complicated problem, so i hope i can make myself clear:
i have a parameter z, which has a keyframed value on every frame.
i also have a parameter y, which depends on z AND the sum of all the values of y before the current frame (because the sum defines the time, at which my expression looks at z).this is my expression (much simplified, but basically that’s the principle):
sum=0;for (i=0; i<=time-0.02; i+=0.02) {
sum += ( y.valueAtTime(i) );
}(z.valueAtTime(sum);
That’s the expression to calculate y.
my comp is in 50fps, that’s why in the loop the steps are 0.02s.alright, now to everybody who could follow to this point:
the problem is, in the loop instead of the previously calculated value for y, it uses the value of y, which is defined before the expression (which is always 100, unless i gave it another value or even keyframed it – what i don’t want, because i want the expression to define the value).
it’s like in the curve-editor, you can also see the original value but if you check the box with the curve-sign, you see the curve after the expression. so in the loop the value before the expression is used instead of the value after the expression. this just to make clear the problem…
the strange thing is – if i use the value of y in any other expression, e.g. to move a null, it uses the value after the expression, just like it should be – so it seems like the loop is the problem?
any suggestions? i’ve been stuck on this for several days now… :/
Thanks for the help!
Noah
