Activity › Forums › Maxon Cinema 4D › Sugg’s for Flowing Line Animation
  • Sugg’s for Flowing Line Animation
    Posted by Jay Ingles on June 11, 2011 at 7:40 pm
    I’m looking for advice on techniques/tools to use to create a fluid flowing line animation. The image below was part of the creative brief and typically i would approach this in After Effects with Particular, but want to use Cinema 4D.
    Sweep Nurbs is my initial inclination, but what are the benefits/limitations of Sweep Nurbs / Tracers / AE Particular?
    The line will need to be customizable and outline/create images the narration speaks about.
    Any advice, Tutorials, or Refs are appreciated.
    Randy Johnson replied 15 years, 3 months ago 2 Members · 3 Replies
  • Randy Johnson
    June 12, 2011 at 9:48 am
    Sweep nurbs and tracers are nice to work with for this in addition to Sketch and Toon you will be able to get good results….there was a tutorial around something about IPOD but I cannot remember where, or who made it.
    /Randy
  • Jay Ingles
    June 12, 2011 at 5:06 pm
    Thanks Randy,
    I got some pleasing test results with spline and Sketch and Toon. Are there any foreseeable problems with using splines and animating S&T start/stops?
    Since im not An experienced c4d user, It seems that S&T may be the easiest, visually pleasing approach…no? Im concerned I might get undesireable results with Tracers/sweep nurbs that I won’t know how to remedy.
    Im Also looking into Mospline.
    More testing to do. Thanks!
  • Randy Johnson
    June 12, 2011 at 6:59 pm
    You get more depth with a sweep nurbs but it is dependent on your lighting and all that. You will want to avoid thin lines with S&T they will get anti ailiasing issues when rendered.
    /Randy
