Activity Forums Adobe After Effects Suggestions on how to remove these puddles?
  • Suggestions on how to remove these puddles?
    Posted by Stephen Pickering on October 11, 2013 at 6:10 pm
    Hi everyone,
    I have this clip https://youtu.be/7YuZHX41rfU (and another similar) which I would like to remove the prominent water puddles from. If it were something on the trailer I would grab a still-frame, perspective crop it in Photoshop, photoshop it, then import back into AE and use either Camera Tracker or Mocha AE to track the footage and attach the photoshopped image.
    But with this the ground will be hard to know how to perspective crop it. Any suggestions?
    -Stephen
    Roland R. kahlenberg replied 12 years, 11 months ago 4 Members · 4 Replies
  • Todd Kopriva
    October 11, 2013 at 6:21 pm
    I’d use the Clone Stamp tool together with motion tracking, like this:
    https://www.video2brain.com/en/lessons/removing-an-object-with-clone-stamp
    After Effects team blog
  • Tero Ahlfors
    October 11, 2013 at 7:08 pm
    I think that could be pretty easy with Mocha Pro’s remove module. Mocha AE doesn’t have that though.
  • Stephen Pickering
    October 11, 2013 at 7:40 pm
    I only have Mocha AE so I’ll try the stamp tool. Thanks again,
    Stephen
  • Roland R. kahlenberg
    October 12, 2013 at 5:27 am
    If you feel confident with replacing something on the trailer with mocha then the workflow and technical requirements to replace the puddles on the ground are actually identical. I suggest that you give it a try.
    Cheers
    RoRK
    Intensive mocha & AE Training in Singapore and Other Dangerous Locations
    Imagineer Systems (mocha) Certified Instructor
    & Adobe After Effects CS6 ACE/ACI
