Activity Forums Adobe Premiere Pro Suddenly this “workstation” can’t even keep up with my other baby PC
  • Suddenly this “workstation” can’t even keep up with my other baby PC
    Posted by Duke Sweden on July 4, 2017 at 1:42 am
    This is so aggravating. What I used to be able to do, albeit very slowly, on my crap PC, I can’t do on this supposedly superior PC. Rendering is a crapshoot, sometimes it encodes all the way, other times it “fails”. about 10 minutes in (this with just some minor lumetri tweaks). Also, I’ll be working on something and the source and program monitors will go black. You can see the video of I play it or scrub the timeline, but if I leave it, they go black. I have to shut PPro and restart.
    I replaced the graphics card, as mentioned previously. I know what I’m doing as far as that’s concerned so I didn’t accidentally not set it correctly or anything. I’ve got about 12 more days to test this thing and I’ve got a 16 gig RAM chip coming Thursday. But I really dread having to yank my two HDD’s out, as well as the new RAM, AND put back the graphics card that came with this.
    I thought XPS 8910’s were decent, if not top of the line. Does any of this sound familiar to anybody? Am I rendering to the wrong hard drive? Just to summarize,
    I have Premiere Pro and Project files on my main HDD, media and cache files on a second HDD, and am encoding to the third HDD.
    As far as the source and program monitors going black I don’t know what the deal is with that.
    Chris Wright replied 9 years, 2 months ago 5 Members · 20 Replies
  • 20 Replies
  • Brent Marginet
    July 4, 2017 at 4:55 am
    Can you post as many hardware specs as possible about your system like current amount of RAM, DDR-X, number and size of sticks, Video Card, CPU, etc. etc.
    Also which Version of Windows are you using 7, 8, 8.1 or 10 and 32 or 64bit.
    OpenCL or CUDA you know the whole ball of wax.
    I will try to help if possible.
    I run primarily Mac but I ran into a very similar issue on my PC recently.
    I started off reseating everything from Power Connectors to RAM Modules and every expansion card that was in the system. I even reset my BIOS back to the Optimized Factory Defaults and also ran MEM Test with no luck. In the end a new clean install of the OS took about a day once all of Windows Updates were done. I must say though the difference was well worth the time it took to reinstall everything. It seems like it’s 10 times faster now.
    Here’s the MEM Test Link.
    https://www.memtest.org
    \”MY MEDIA MOTO: If you think three copies of your media is enough.
    Take a moment to place a value on it and then maybe add two more.
    Hard Drives are now stupidly cheap. A RE-SHOOT AND YOUR TIME AREN\’T.\”
  • Duke Sweden
    July 4, 2017 at 11:13 am
    Thanks, Brent. I’ll get that information for you, but as I said, even my consumer level PC with 12 gigs of RAM, i5 core processor, integrated Intel graphics card, etc., while slow, never caused these problems. Let me run Speccy and I’ll get you the details. For now I can tell you it’s running
    64 bit Windows 10 with updates,
    1 stick of 16 gig of DDR-4 RAM (soon to be 32 gigs),
    i7 processor (6700 version. Yeah, I know…),
    CUDA (which, after the encode failed and I re-opened the project was told by PPro that my PC doesn’t have CUDA and would start in software mode, another glitch the other PC never had).
    And, yes, I did install the CUDA driver from Nvidia and updated the drivers for the new graphics card (GeForce 1050).
    I guess that’s everything you asked for, actually. Thanks again.
    Oh, and I just got this 4 days ago. I’ve got 11 more days to get it right before I bring it back.
  • Duke Sweden
    July 4, 2017 at 11:19 am
    Here’s the specs from Speccy. Hopefully it will format correctly and not be a jumbled mess
    Summary
    Operating System
    Windows 10 Home 64-bit
    CPU
    Intel Core i7 6700 @ 3.40GHz 30 °C
    Skylake 14nm Technology
    RAM
    16.0GB Single-Channel Unknown @ 1063MHz (15-15-15-36)
    Motherboard
    Dell Inc. 0WPMFG (U3E1) 28 °C
    Graphics
    E32-C1 (1920×1080@60Hz)
    SONY TV (1360×768@60Hz)
    Intel HD Graphics 530 (Dell)
    2047MB NVIDIA GeForce GTX 1050 (PNY) 28 °C
    ForceWare version: 376.51
    SLI Disabled
    Storage
    931GB Seagate ST1000DM003-1SB102 (SATA) 32 °C
    1863GB Seagate ST2000DM001-1CH164 (SATA) 32 °C
    465GB Seagate ST3500413AS (SATA) 32 °C
    Optical Drives
    HL-DT-ST DVD+-RW GU90N
    Audio
    Realtek Audio
    Operating System
    Computer type: Desktop
    Installation Date: 6/29/2017 3:00:40 PM
    Windows Security Center
    User Account Control (UAC) Enabled
    Notify level 1 – Rare Notify
    Firewall Enabled
    Windows Update
    AutoUpdate Not configured
    Windows Defender
    Windows Defender Enabled
    Antivirus
    Antivirus Enabled
    Display Name Windows Defender
    Virus Signature Database Up to date
    .NET Frameworks installed
    v4.7 Full
    v4.7 Client
    v3.5 SP1
    v3.0 SP2
    v2.0 SP2
    Internet Explorer
    Version 11.413.15063.0
    PowerShell
    Version 5.1.15063.0
    Environment Variables
    USERPROFILE C:\Users\john_
    SystemRoot C:\WINDOWS
    User Variables
    OneDrive C:\Users\john_\OneDrive
    Path C:\Users\john_\AppData\Local\Microsoft\WindowsApps
    TEMP C:\Users\john_\AppData\Local\Temp
    TMP C:\Users\john_\AppData\Local\Temp
    Machine Variables
    ComSpec C:\WINDOWS\system32\cmd.exe
    CUDA_PATH C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v8.0
    CUDA_PATH_V8_0 C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v8.0
    INTEL_DEV_REDIST C:\Program Files (x86)\Common Files\Intel\Shared Libraries\
    MIC_LD_LIBRARY_PATH %INTEL_DEV_REDIST%compiler\lib\mic
    NUMBER_OF_PROCESSORS 8
    NVCUDASAMPLES8_0_ROOT C:\ProgramData\NVIDIA Corporation\CUDA Samples\v8.0
    NVCUDASAMPLES_ROOT C:\ProgramData\NVIDIA Corporation\CUDA Samples\v8.0
    NVTOOLSEXT_PATH C:\Program Files\NVIDIA Corporation\NvToolsExt\
    OS Windows_NT
    Path %INTEL_DEV_REDIST%redist\intel64\compiler
    C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v8.0\bin
    C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v8.0\libnvvp
    C:\Program Files (x86)\Intel\iCLS Client\
    C:\Program Files\Intel\iCLS Client\
    C:\Windows\system32
    C:\Windows
    C:\Windows\System32\Wbem
    C:\Windows\System32\WindowsPowerShell\v1.0\
    C:\Program Files (x86)\Intel\Intel Management Engine Components\DAL
    C:\Program Files\Intel\Intel Management Engine Components\DAL
    C:\Program Files (x86)\Intel\Intel Management Engine Components\IPT
    C:\Program Files\Intel\Intel Management Engine Components\IPT
    C:\Program Files\Intel\WiFi\bin\
    C:\Program Files\Common Files\Intel\WirelessCommon\
    C:\Program Files (x86)\NVIDIA Corporation\PhysX\Common
    C:\WINDOWS\system32
    C:\WINDOWS
    C:\WINDOWS\System32\Wbem
    C:\WINDOWS\System32\WindowsPowerShell\v1.0\
    PATHEXT .COM;.EXE;.BAT;.CMD;.VBS;.VBE;.JS;.JSE;.WSF;.WSH;.MSC
    PROCESSOR_ARCHITECTURE AMD64
    PROCESSOR_IDENTIFIER Intel64 Family 6 Model 94 Stepping 3, GenuineIntel
    PROCESSOR_LEVEL 6
    PROCESSOR_REVISION 5e03
    PSModulePath %ProgramFiles%\WindowsPowerShell\Modules
    C:\WINDOWS\system32\WindowsPowerShell\v1.0\Modules
    RG_GPU_FRAMEWORK_ENGINE_RESOURCEDIR C:\Program Files\Red Giant\RGFX
    TEMP C:\WINDOWS\TEMP
    TMP C:\WINDOWS\TEMP
    USERNAME SYSTEM
    windir C:\WINDOWS
    Power Profile
    Active power scheme No energy savings
    Hibernation Enabled
    Turn Off Monitor after: (On AC Power) 45 min
    Turn Off Hard Disk after: (On AC Power) 20 min
    Suspend after: (On AC Power) 60 min
    Screen saver Disabled
    Uptime
    Current Session
    Current Time 7/4/2017 7:17:02 AM
    Current Uptime 1,555 sec (0 d, 00 h, 25 m, 55 s)
    Last Boot Time 7/4/2017 6:51:07 AM
    Services
    Running Adobe Acrobat Update Service
    Running Adobe Genuine Software Integrity Service
    Running AdobeUpdateService
    Running Application Information
    Running AppX Deployment Service (AppXSVC)
    Running Background Intelligent Transfer Service
    Running Background Tasks Infrastructure Service
    Running Base Filtering Engine
    Running Bluetooth Support Service
    Running CNG Key Isolation
    Running COM+ Event System
    Running Computer Browser
    Running Connected Devices Platform Service
    Running Connected Devices Platform User Service_5d85f
    Running Connected User Experiences and Telemetry
    Running Contact Data_5d85f
    Running CoreMessaging
    Running Credential Manager
    Running Cryptographic Services
    Running Data Usage
    Running DbxSvc
    Running DCOM Server Process Launcher
    Running Dell Customer Connect
    Running Dell Data Vault Collector
    Running Dell Data Vault Processor
    Running Dell Data Vault Service API
    Running Dell Foundation Services
    Running Dell Help & Support
    Running Dell SupportAssist Agent
    Running Dell Update Service
    Running Device Association Service
    Running DHCP Client
    Running Diagnostic Policy Service
    Running Diagnostic Service Host
    Running Diagnostic System Host
    Running Distributed Link Tracking Client
    Running DNS Client
    Running Function Discovery Provider Host
    Running Function Discovery Resource Publication
    Running Geolocation Service
    Running HomeGroup Listener
    Running HomeGroup Provider
    Running Human Interface Device Service
    Running Intel Bluetooth Service
    Running Intel Dynamic Application Loader Host Interface Service
    Running Intel HD Graphics Control Panel Service
    Running Intel Management and Security Application Local Management Service
    Running Intel PROSet/Wireless Event Log
    Running Intel PROSet/Wireless Registry Service
    Running Intel PROSet/Wireless Zero Configuration Service
    Running Intel Rapid Storage Technology
    Running Intel Ready Mode Technology
    Running Intel Security Assist Helper
    Running IP Helper
    Running Local Session Manager
    Running Network Connected Devices Auto-Setup
    Running Network Connection Broker
    Running Network List Service
    Running Network Location Awareness
    Running Network Store Interface Service
    Running NVIDIA Display Container LS
    Running NVIDIA LocalSystem Container
    Running NVIDIA Telemetry Container
    Running Peer Name Resolution Protocol
    Running Peer Networking Grouping
    Running Peer Networking Identity Manager
    Running Plug and Play
    Running Power
    Running Print Spooler
    Running Product Registration
    Running Program Compatibility Assistant Service
    Running Realtek Audio Service
    Running Remote Procedure Call (RPC)
    Running RPC Endpoint Mapper
    Running Security Accounts Manager
    Running Security Center
    Running Server
    Running Shell Hardware Detection
    Running SSDP Discovery
    Running State Repository Service
    Running Storage Service
    Running Superfetch
    Running Sync Host_5d85f
    Running System Event Notification Service
    Running System Events Broker
    Running Task Scheduler
    Running TCP/IP NetBIOS Helper
    Running Telephony
    Running Themes
    Running Tile Data model server
    Running Time Broker
    Running TokenBroker
    Running UPnP Device Host
    Running User Data Access_5d85f
    Running User Data Storage_5d85f
    Running User Manager
    Running User Profile Service
    Running Windows Audio
    Running Windows Audio Endpoint Builder
    Running Windows Connection Manager
    Running Windows Defender Antivirus Network Inspection Service
    Running Windows Defender Antivirus Service
    Running Windows Defender Security Center Service
    Running Windows Driver Foundation – User-mode Driver Framework
    Running Windows Event Log
    Running Windows Firewall
    Running Windows Font Cache Service
    Running Windows Management Instrumentation
    Running Windows Media Player Network Sharing Service
    Running Windows Presentation Foundation Font Cache 3.0.0.0
    Running Windows Push Notifications System Service
    Running Windows Push Notifications User Service_5d85f
    Running Windows Search
    Running Windows Update
    Running WinHTTP Web Proxy Auto-Discovery Service
    Running WLAN AutoConfig
    Running WMI Performance Adapter
    Running Workstation
    Stopped ActiveX Installer (AxInstSV)
    Stopped AllJoyn Router Service
    Stopped App Readiness
    Stopped Application Identity
    Stopped Application Layer Gateway Service
    Stopped Auto Time Zone Updater
    Stopped BitLocker Drive Encryption Service
    Stopped Block Level Backup Engine Service
    Stopped Bluetooth Handsfree Service
    Stopped Certificate Propagation
    Stopped Client License Service (ClipSVC)
    Stopped COM+ System Application
    Stopped Data Sharing Service
    Stopped Delivery Optimization
    Stopped Dell Digital Delivery Service
    Stopped Device Install Service
    Stopped Device Management Enrollment Service
    Stopped Device Setup Manager
    Stopped DevicesFlow_5d85f
    Stopped DevQuery Background Discovery Broker
    Stopped Distributed Transaction Coordinator
    Stopped dmwappushsvc
    Stopped Downloaded Maps Manager
    Stopped Dropbox Update Service (dbupdate)
    Stopped Dropbox Update Service (dbupdatem)
    Stopped Embedded Mode
    Stopped Encrypting File System (EFS)
    Stopped Enterprise App Management Service
    Stopped Extensible Authentication Protocol
    Stopped Fax
    Stopped File History Service
    Stopped Google Update Service (gupdate)
    Stopped Google Update Service (gupdatem)
    Stopped Group Policy Client
    Stopped HV Host Service
    Stopped Hyper-V Data Exchange Service
    Stopped Hyper-V Guest Service Interface
    Stopped Hyper-V Guest Shutdown Service
    Stopped Hyper-V Heartbeat Service
    Stopped Hyper-V PowerShell Direct Service
    Stopped Hyper-V Remote Desktop Virtualization Service
    Stopped Hyper-V Time Synchronization Service
    Stopped Hyper-V Volume Shadow Copy Requestor
    Stopped IKE and AuthIP IPsec Keying Modules
    Stopped Infrared monitor service
    Stopped Intel Capability Licensing Service TCP IP Interface
    Stopped Intel Content Protection HDCP Service
    Stopped Intel Content Protection HECI Service
    Stopped Intel Security Assist
    Stopped Interactive Services Detection
    Stopped Internet Connection Sharing (ICS)
    Stopped IP Translation Configuration Service
    Stopped IPsec Policy Agent
    Stopped KtmRm for Distributed Transaction Coordinator
    Stopped Link-Layer Topology Discovery Mapper
    Stopped LPA Service
    Stopped MessagingService_5d85f
    Stopped Microsoft Diagnostics Hub Standard Collector Service
    Stopped Microsoft Account Sign-in Assistant
    Stopped Microsoft iSCSI Initiator Service
    Stopped Microsoft Passport
    Stopped Microsoft Passport Container
    Stopped Microsoft Software Shadow Copy Provider
    Stopped Microsoft Storage Spaces SMP
    Stopped Microsoft Windows SMS Router Service.
    Stopped Mozilla Maintenance Service
    Stopped Natural Authentication
    Stopped Net.Tcp Port Sharing Service
    Stopped Netlogon
    Stopped Network Connections
    Stopped Network Connectivity Assistant
    Stopped Network Setup Service
    Stopped NVIDIA NetworkService Container
    Stopped Office 64 Source Engine
    Stopped Optimize drives
    Stopped Payments and NFC/SE Manager
    Stopped Performance Counter DLL Host
    Stopped Performance Logs & Alerts
    Stopped Phone Service
    Stopped PNRP Machine Name Publication Service
    Stopped Portable Device Enumerator Service
    Stopped Printer Extensions and Notifications
    Stopped Problem Reports and Solutions Control Panel Support
    Stopped Quality Windows Audio Video Experience
    Stopped Radio Management Service
    Stopped Remote Access Auto Connection Manager
    Stopped Remote Access Connection Manager
    Stopped Remote Desktop Configuration
    Stopped Remote Desktop Services
    Stopped Remote Desktop Services UserMode Port Redirector
    Stopped Remote Procedure Call (RPC) Locator
    Stopped Remote Registry
    Stopped Retail Demo Service
    Stopped Routing and Remote Access
    Stopped Secondary Logon
    Stopped Secure Socket Tunneling Protocol Service
    Stopped Sensor Data Service
    Stopped Sensor Monitoring Service
    Stopped Sensor Service
    Stopped Shared PC Account Manager
    Stopped Smart Card
    Stopped Smart Card Device Enumeration Service
    Stopped Smart Card Removal Policy
    Stopped SNMP Trap
    Stopped Software Protection
    Stopped Spot Verifier
    Stopped Still Image Acquisition Events
    Stopped Storage Tiers Management
    Stopped Touch Keyboard and Handwriting Panel Service
    Stopped Update Orchestrator Service
    Stopped Virtual Disk
    Stopped Volume Shadow Copy
    Stopped WalletService
    Stopped WebClient
    Stopped Wi-Fi Direct Services Connection Manager Service
    Stopped Windows Backup
    Stopped Windows Biometric Service
    Stopped Windows Camera Frame Server
    Stopped Windows Connect Now – Config Registrar
    Stopped Windows Encryption Provider Host Service
    Stopped Windows Error Reporting Service
    Stopped Windows Event Collector
    Stopped Windows Image Acquisition (WIA)
    Stopped Windows Insider Service
    Stopped Windows Installer
    Stopped Windows License Manager Service
    Stopped Windows Mobile Hotspot Service
    Stopped Windows Modules Installer
    Stopped Windows Perception Service
    Stopped Windows Remote Management (WS-Management)
    Stopped Windows Time
    Stopped Wired AutoConfig
    Stopped Wireless PAN DHCP Server
    Stopped Work Folders
    Stopped WWAN AutoConfig
    Stopped Xbox Accessory Management Service
    Stopped Xbox Game Monitoring
    Stopped Xbox Live Auth Manager
    Stopped Xbox Live Game Save
    Stopped Xbox Live Networking Service
    TimeZone
    TimeZone GMT -5:00 Hours
    Language English (United States)
    Location United States
    Format English (United States)
    Currency $
    Date Format M/d/yyyy
    Time Format h:mm:ss tt
    Scheduler
    7/4/2017 7:56 AM; DropboxUpdateTaskMachineUA
    7/4/2017 8:05 AM; GoogleUpdateTaskMachineUA
    7/4/2017 10:08 AM; SystemToolsDailyTest
    7/4/2017 1:56 PM; DropboxUpdateTaskMachineCore
    7/4/2017 2:05 PM; GoogleUpdateTaskMachineCore
    7/4/2017 6:40 PM; Red Giant Link
    7/5/2017 2:00 AM; AdobeAAMUpdater-1.0-MicrosoftAccount-john_hopkin68@hotmail.com
    7/5/2017 6:00 AM; Adobe Acrobat Update Task
    7/5/2017 6:43 AM; PCDDataUploadTask
    7/5/2017 6:54 AM; AutoKMS
    7/5/2017 6:10 PM; OneDrive Standalone Update Task v2
    7/6/2017 6:00 AM; PCDoctorBackgroundMonitorTask
    7/6/2017 11:50 AM; Dell SupportAssistAgent AutoUpdate
    Dell Cleanup
    DropboxOEM
    PCDEventLauncherTask
    RtHDVBg_PushButton
    Hotfixes
    Installed
    7/4/2017 Definition Update for Windows Defender – KB2267602 (Definition 1.247.459.0)
    Install this update to revise the definition files that are used
    to detect viruses, spyware, and other potentially unwanted software.
    Once you have installed this item, it cannot be removed.
    7/4/2017 Definition Update for Windows Defender – KB2267602 (Definition 1.247.448.0)
    7/3/2017 Definition Update for Windows Defender – KB2267602 (Definition 1.247.440.0)
    7/3/2017 Definition Update for Windows Defender – KB2267602 (Definition 1.247.421.0)
    7/2/2017 Definition Update for Windows Defender – KB2267602 (Definition 1.247.407.0)
    7/2/2017 Definition Update for Windows Defender – KB2267602 (Definition 1.247.401.0)
    7/2/2017 Definition Update for Windows Defender – KB2267602 (Definition 1.247.400.0)
    7/2/2017 Definition Update for Windows Defender – KB2267602 (Definition 1.247.399.0)
    7/1/2017 Definition Update for Windows Defender – KB2267602 (Definition 1.247.385.0)
    7/1/2017 Definition Update for Windows Defender – KB2267602 (Definition 1.247.384.0)
    6/30/2017 Definition Update for Windows Defender – KB2267602 (Definition 1.247.359.0)
    6/30/2017 Definition Update for Windows Defender – KB2267602 (Definition 1.247.356.0)
    6/30/2017 Definition Update for Windows Defender – KB2267602 (Definition 1.247.345.0)
    6/30/2017 Definition Update for Windows Defender – KB2267602 (Definition 1.247.322.0)
    6/30/2017 Windows Malicious Software Removal Tool for Windows 8, 8.1, 10 and Windows Server 2012, 2012 R2, 2016 x64 Edition – June 2017 (KB890830)
    After the download, this tool runs one time to check your computer
    for infection by specific, prevalent malicious software (including
    Blaster, Sasser, and Mydoom) and helps remove any infection that
    is found. If an infection is found, the tool will display a status
    report the next time that you start your computer. A new version
    of the tool will be offered every month. If you want to manually
    run the tool on your computer, you can download a copy from the
    Microsoft Download Center, or you can run an online version from
    microsoft.com. This tool is not a replacement for an antivirus
    product. To help protect your computer, you should use an antivirus
    product.
    6/30/2017 Definition Update for Windows Defender – KB2267602 (Definition 1.247.316.0)
    6/29/2017 Definition Update for Windows Defender – KB2267602 (Definition 1.247.301.0)
    6/29/2017 NVIDIA – Display – 5/1/2017 12:00:00 AM – 22.21.13.8205
    NVIDIA Display driver update released in May 2017
    Not Installed
    Installation Status Failed
    System Folders
    Application Data C:\ProgramData
    Cookies C:\Users\john_\AppData\Local\Microsoft\Windows\INetCookies
    Desktop C:\Users\john_\Desktop
    Documents C:\Users\Public\Documents
    Fonts C:\WINDOWS\Fonts
    Global Favorites C:\Users\john_\Favorites
    Internet History C:\Users\john_\AppData\Local\Microsoft\Windows\History
    Local Application Data C:\Users\john_\AppData\Local
    Music C:\Users\Public\Music
    Path for burning CD C:\Users\john_\AppData\Local\Microsoft\Windows\Burn\Burn
    Physical Desktop C:\Users\john_\Desktop
    Pictures C:\Users\Public\Pictures
    Program Files C:\Program Files
    Public Desktop C:\Users\Public\Desktop
    Start Menu C:\ProgramData\Microsoft\Windows\Start Menu
    Start Menu Programs C:\ProgramData\Microsoft\Windows\Start Menu\Programs
    Startup C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Startup
    Templates C:\ProgramData\Microsoft\Windows\Templates
    Temporary Internet Files C:\Users\john_\AppData\Local\Microsoft\Windows\INetCache
    User Favorites C:\Users\john_\Favorites
    Videos C:\Users\Public\Videos
    Windows Directory C:\WINDOWS
    Windows/System C:\WINDOWS\system32
    Process List
    acrotray.exe
    Process ID 10284
    User john_
    Domain DESKTOP-1R8PRD3
    Path C:\Program Files (x86)\Adobe\Acrobat DC\Acrobat\acrotray.exe
    Memory Usage 7.92 MB
    Peak Memory Usage 7.94 MB
    Adobe CEF Helper.exe
    Process ID 11032
    User john_
    Path C:\Program Files (x86)\Common Files\Adobe\Adobe Desktop Common\HEX\Adobe CEF Helper.exe
    Memory Usage 88 MB
    Peak Memory Usage 108 MB
    Adobe Desktop Service.exe
    Process ID 10964
    User john_
    Path C:\Program Files (x86)\Common Files\Adobe\Adobe Desktop Common\ADS\Adobe Desktop Service.exe
    Memory Usage 97 MB
    Peak Memory Usage 118 MB
    AdobeIPCBroker.exe
    Process ID 10544
    User john_
    Path C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\IPC\AdobeIPCBroker.exe
    Memory Usage 11 MB
    Peak Memory Usage 12 MB
    AdobeUpdateService.exe
    Process ID 4232
    User SYSTEM
    Domain NT AUTHORITY
    Path C:\Program Files (x86)\Common Files\Adobe\Adobe Desktop Common\ElevationManager\AdobeUpdateService.exe
    Memory Usage 9.02 MB
    Peak Memory Usage 9.08 MB
    AGSService.exe
    Process ID 4240
    User SYSTEM
    Domain NT AUTHORITY
    Path C:\Program Files (x86)\Common Files\Adobe\AdobeGCClient\AGSService.exe
    Memory Usage 15 MB
    Peak Memory Usage 16 MB
    ApplicationFrameHost.exe
    Process ID 6444
    User john_
    Path C:\Windows\System32\ApplicationFrameHost.exe
    Memory Usage 35 MB
    Peak Memory Usage 35 MB
    armsvc.exe
    Process ID 4900
    User SYSTEM
    Domain NT AUTHORITY
    Path C:\Program Files (x86)\Common Files\Adobe\ARM\1.0\armsvc.exe
    Memory Usage 6.64 MB
    Peak Memory Usage 6.71 MB
    audiodg.exe
    Process ID 13720
    User LOCAL SERVICE
    Domain NT AUTHORITY
    Path C:\Windows\System32\audiodg.exe
    Memory Usage 18 MB
    Peak Memory Usage 32 MB
    backgroundTaskHost.exe
    Process ID 5096
    User john_
    Path C:\Windows\System32\backgroundTaskHost.exe
    Memory Usage 21 MB
    Peak Memory Usage 21 MB
    CCLibrary.exe
    Process ID 3920
    User john_
    Path C:\Program Files (x86)\Adobe\Adobe Creative Cloud\CCLibrary\CCLibrary.exe
    Memory Usage 2.68 MB
    Peak Memory Usage 2.68 MB
    CCXProcess.exe
    Process ID 9144
    User john_
    Path C:\Program Files (x86)\Adobe\Adobe Creative Cloud\CCXProcess\CCXProcess.exe
    Memory Usage 2.63 MB
    Peak Memory Usage 2.63 MB
    chrome.exe
    Process ID 2648
    User john_
    Path C:\Program Files (x86)\Google\Chrome\Application\chrome.exe
    Memory Usage 116 MB
    Peak Memory Usage 199 MB
    chrome.exe
    Process ID 15140
    User john_
    Memory Usage 465 MB
    Peak Memory Usage 505 MB
    chrome.exe
    Process ID 15132
    User john_
    Memory Usage 199 MB
    Peak Memory Usage 247 MB
    chrome.exe
    Process ID 15124
    User john_
    Memory Usage 140 MB
    Peak Memory Usage 187 MB
    chrome.exe
    Process ID 15116
    User john_
    Memory Usage 121 MB
    Peak Memory Usage 168 MB
    chrome.exe
    Process ID 12992
    User john_
    Memory Usage 34 MB
    chrome.exe
    Process ID 1336
    User john_
    Memory Usage 140 MB
    Peak Memory Usage 179 MB
    chrome.exe
    Process ID 10428
    User john_
    Memory Usage 38 MB
    Peak Memory Usage 38 MB
    chrome.exe
    Process ID 11328
    User john_
    Memory Usage 35 MB
    chrome.exe
    Process ID 12824
    User john_
    Memory Usage 65 MB
    Peak Memory Usage 84 MB
    chrome.exe
    Process ID 11772
    User john_
    Memory Usage 187 MB
    chrome.exe
    Process ID 14320
    User john_
    Memory Usage 85 MB
    Peak Memory Usage 147 MB
    chrome.exe
    Process ID 1424
    User john_
    Memory Usage 39 MB
    Peak Memory Usage 41 MB
    chrome.exe
    Process ID 14080
    User john_
    Memory Usage 95 MB
    Peak Memory Usage 117 MB
    chrome.exe
    Process ID 12956
    User john_
    Memory Usage 199 MB
    Peak Memory Usage 282 MB
    chrome.exe
    Process ID 13468
    User john_
    Memory Usage 9.03 MB
    Peak Memory Usage 9.05 MB
    chrome.exe
    Process ID 13452
    User john_
    Memory Usage 9.68 MB
    Peak Memory Usage 9.70 MB
    chrome.exe
    Process ID 8448
    User john_
    Memory Usage 93 MB
    Peak Memory Usage 115 MB
    conhost.exe
    Process ID 7232
    User john_
    Path C:\Windows\System32\conhost.exe
    Memory Usage 96 KB
    Peak Memory Usage 9.96 MB
    conhost.exe
    Process ID 4744
    User SYSTEM
    Domain NT AUTHORITY
    Memory Usage 5.66 MB
    Peak Memory Usage 5.75 MB
    conhost.exe
    Process ID 4056
    User john_
    Memory Usage 8.83 MB
    Peak Memory Usage 9.82 MB
    conhost.exe
    Process ID 12916
    User john_
    Memory Usage 11 MB
    Peak Memory Usage 11 MB
    conhost.exe
    Process ID 8576
    User john_
    Memory Usage 8.86 MB
    Peak Memory Usage 9.80 MB
    CoreSync.exe
    Process ID 9160
    User john_
    Path C:\Program Files (x86)\Adobe\Adobe Creative Cloud\CoreSync\CoreSync.exe
    Memory Usage 39 MB
    Creative Cloud.exe
    Process ID 10204
    User john_
    Path C:\Program Files (x86)\Adobe\Adobe Creative Cloud\ACC\Creative Cloud.exe
    Memory Usage 71 MB
    Peak Memory Usage 78 MB
    csrss.exe
    Process ID 908
    User SYSTEM
    Domain NT AUTHORITY
    Path C:\Windows\System32\csrss.exe
    Memory Usage 4.98 MB
    Peak Memory Usage 17 MB
    csrss.exe
    Process ID 792
    User SYSTEM
    Domain NT AUTHORITY
    Memory Usage 5.25 MB
    Peak Memory Usage 7.61 MB
    dasHost.exe
    Process ID 2748
    User LOCAL SERVICE
    Domain NT AUTHORITY
    Path C:\Windows\System32\dasHost.exe
    Memory Usage 16 MB
    DbxSvc.exe
    Process ID 3752
    User SYSTEM
    Domain NT AUTHORITY
    Path C:\Windows\System32\DbxSvc.exe
    Memory Usage 6.29 MB
    Peak Memory Usage 6.42 MB
    DCCService.exe
    Process ID 1008
    User SYSTEM
    Domain NT AUTHORITY
    Path C:\Program Files (x86)\Dell Customer Connect\DCCService.exe
    Memory Usage 36 MB
    Peak Memory Usage 36 MB
    DDVCollectorSvcApi.exe
    Process ID 13116
    User SYSTEM
    Domain NT AUTHORITY
    Path C:\Program Files\Dell\DellDataVault\DDVCollectorSvcApi.exe
    Memory Usage 7.10 MB
    Peak Memory Usage 7.12 MB
    DDVDataCollector.exe
    Process ID 12980
    User SYSTEM
    Domain NT AUTHORITY
    Path C:\Program Files\Dell\DellDataVault\DDVDataCollector.exe
    Memory Usage 25 MB
    Peak Memory Usage 25 MB
    DDVRulesProcessor.exe
    Process ID 6944
    User SYSTEM
    Domain NT AUTHORITY
    Path C:\Program Files\Dell\DellDataVault\DDVRulesProcessor.exe
    Memory Usage 14 MB
    Peak Memory Usage 15 MB
    DellSystemDetect.exe
    Process ID 8652
    User john_
    Path C:\Users\john_\AppData\Local\Apps\2.0\7QTX0NL5.H1Y\G386GXKX.RO4\dell..tion_831211ca63b981c5_0008.0005_9a48d74816d64e41\DellSystemDetect.exe
    Memory Usage 41 MB
    DellUpService.exe
    Process ID 7916
    User SYSTEM
    Domain NT AUTHORITY
    Path C:\Program Files (x86)\Dell Update\DellUpService.exe
    Memory Usage 43 MB
    Peak Memory Usage 43 MB
    DellUpTray.exe
    Process ID 10372
    User john_
    Path C:\Program Files (x86)\Dell Update\DellUpTray.exe
    Memory Usage 56 MB
    Peak Memory Usage 64 MB
    DFS.Common.Agent.exe
    Process ID 12728
    User john_
    Path C:\Program Files\Dell\Dell Foundation Services\DFS.Common.Agent.exe
    Memory Usage 22 MB
    Peak Memory Usage 34 MB
    DFSSvc.exe
    Process ID 4032
    User SYSTEM
    Domain NT AUTHORITY
    Path C:\Program Files\Dell\Dell Foundation Services\DFSSvc.exe
    Memory Usage 60 MB
    Peak Memory Usage 60 MB
    dllhost.exe
    Process ID 13664
    User john_
    Path C:\Windows\System32\dllhost.exe
    Memory Usage 11 MB
    dllhost.exe
    Process ID 10000
    User SYSTEM
    Domain NT AUTHORITY
    Memory Usage 7.25 MB
    Peak Memory Usage 7.45 MB
    dllhost.exe
    Process ID 13400
    User SYSTEM
    Domain NT AUTHORITY
    Memory Usage 5.95 MB
    Peak Memory Usage 5.95 MB
    dllhost.exe
    Process ID 6668
    User SYSTEM
    Domain NT AUTHORITY
    Peak Memory Usage 6.29 MB
    Dropbox.exe
    Process ID 10400
    User john_
    Path C:\Program Files (x86)\Dropbox\Client\Dropbox.exe
    Memory Usage 6.94 MB
    Peak Memory Usage 7.04 MB
    Dropbox.exe
    Process ID 7876
    User john_
    Memory Usage 122 MB
    Peak Memory Usage 130 MB
    DropboxUpdate.exe
    Process ID 7428
    User SYSTEM
    Domain NT AUTHORITY
    Path C:\Program Files (x86)\Dropbox\Update\DropboxUpdate.exe
    Memory Usage 44 KB
    Peak Memory Usage 8.56 MB
    dwm.exe
    Process ID 1300
    User DWM-1
    Domain Window Manager
    Path C:\Windows\System32\dwm.exe
    Memory Usage 47 MB
    Peak Memory Usage 48 MB
    EvtEng.exe
    Process ID 3876
    User SYSTEM
    Domain NT AUTHORITY
    Path C:\Program Files\Intel\WiFi\bin\EvtEng.exe
    Memory Usage 14 MB
    Peak Memory Usage 14 MB
    explorer.exe
    Process ID 7988
    User john_
    Path C:\Windows\explorer.exe
    Memory Usage 112 MB
    Peak Memory Usage 123 MB
    fontdrvhost.exe
    Process ID 816
    User UMFD-0
    Domain Font Driver Host
    Path C:\Windows\System32\fontdrvhost.exe
    Memory Usage 14 MB
    fontdrvhost.exe
    Process ID 1108
    User UMFD-1
    Memory Usage 36 MB
    HxOutlook.exe
    Process ID 12468
    User john_
    Path C:\Program Files\WindowsApps\microsoft.windowscommunicationsapps_17.8241.41125.0_x64__8wekyb3d8bbwe\HxOutlook.exe
    Memory Usage 62 MB
    Peak Memory Usage 100 MB
    HxTsr.exe
    Process ID 11540
    User john_
    Path C:\Program Files\WindowsApps\microsoft.windowscommunicationsapps_17.8241.41125.0_x64__8wekyb3d8bbwe\HxTsr.exe
    Memory Usage 37 MB
    Peak Memory Usage 37 MB
    IAStorDataMgrSvc.exe
    Process ID 6800
    User SYSTEM
    Domain NT AUTHORITY
    Path C:\Program Files\Intel\Intel Rapid Storage Technology\IAStorDataMgrSvc.exe
    Memory Usage 46 MB
    IAStorIcon.exe
    Process ID 4016
    User john_
    Path C:\Program Files\Intel\Intel Rapid Storage Technology\IAStorIcon.exe
    Memory Usage 35 MB
    ibtsiva.exe
    Process ID 3760
    User SYSTEM
    Domain NT AUTHORITY
    Path C:\Windows\System32\ibtsiva.exe
    Memory Usage 4.44 MB
    Peak Memory Usage 4.58 MB
    igfxCUIService.exe
    Process ID 2192
    User SYSTEM
    Domain NT AUTHORITY
    Path C:\Windows\System32\DriverStore\FileRepository\ki119562.inf_amd64_6a130ba6366a3570\igfxCUIService.exe
    Memory Usage 8.00 MB
    Peak Memory Usage 8.23 MB
    igfxEM.exe
    Process ID 8120
    User john_
    Path C:\Windows\System32\DriverStore\FileRepository\ki119562.inf_amd64_6a130ba6366a3570\igfxEM.exe
    Memory Usage 12 MB
    IRMTService.exe
    Process ID 3744
    User SYSTEM
    Domain NT AUTHORITY
    Path C:\Program Files\Intel\Intel Ready Mode Technology\IRMTService.exe
    Memory Usage 10 MB
    Peak Memory Usage 10 MB
    isaHelperService.exe
    Process ID 3892
    User SYSTEM
    Domain NT AUTHORITY
    Path C:\Program Files (x86)\Intel\Intel Security Assist\isaHelperService.exe
    Memory Usage 3.44 MB
    Peak Memory Usage 3.50 MB
    jhi_service.exe
    Process ID 11044
    User SYSTEM
    Domain NT AUTHORITY
    Path C:\Program Files (x86)\Intel\Intel Management Engine Components\DAL\jhi_service.exe
    Memory Usage 6.28 MB
    Peak Memory Usage 6.36 MB
    LMS.exe
    Process ID 2156
    User SYSTEM
    Domain NT AUTHORITY
    Path C:\Program Files (x86)\Intel\Intel Management Engine Components\LMS\LMS.exe
    Memory Usage 12 MB
    Peak Memory Usage 13 MB
    lsass.exe
    Process ID 996
    User SYSTEM
    Domain NT AUTHORITY
    Path C:\Windows\System32\lsass.exe
    Memory Usage 17 MB
    MDLCSvc.exe
    Process ID 2248
    User SYSTEM
    Domain NT AUTHORITY
    Path C:\Program Files\Dell\Dell Help & Support\MDLCSvc.exe
    Memory Usage 56 MB
    Peak Memory Usage 57 MB
    Memory Compression
    Process ID 4424
    User SYSTEM
    Domain NT AUTHORITY
    Memory Usage 10 MB
    MSASCuiL.exe
    Process ID 796
    User john_
    Path C:\Program Files\Windows Defender\MSASCuiL.exe
    Memory Usage 9.20 MB
    Peak Memory Usage 9.22 MB
    MsMpEng.exe
    Process ID 4248
    User SYSTEM
    Domain NT AUTHORITY
    Path C:\Program Files\Windows Defender\MsMpEng.exe
    Memory Usage 149 MB
    Peak Memory Usage 527 MB
    NisSrv.exe
    Process ID 9608
    User LOCAL SERVICE
    Domain NT AUTHORITY
    Path C:\Program Files\Windows Defender\NisSrv.exe
    Memory Usage 12 MB
    node.exe
    Process ID 9136
    User john_
    Path C:\Program Files (x86)\Adobe\Adobe Creative Cloud\CCXProcess\libs\node.exe
    Memory Usage 62 MB
    Peak Memory Usage 72 MB
    node.exe
    Process ID 4008
    User john_
    Path C:\Program Files (x86)\Adobe\Adobe Creative Cloud\CCLibrary\libs\node.exe
    Memory Usage 55 MB
    Peak Memory Usage 61 MB
    nvapiw.exe
    Process ID 6316
    User john_
    Path C:\Program Files\Dell\DellDataVault\nvapiw.exe
    Peak Memory Usage 8.97 MB
    nvcontainer.exe
    Process ID 3736
    User SYSTEM
    Domain NT AUTHORITY
    Path C:\Program Files\NVIDIA Corporation\NvContainer\nvcontainer.exe
    Memory Usage 22 MB
    Peak Memory Usage 23 MB
    nvcontainer.exe
    Process ID 7236
    User john_
    Path C:\Program Files (x86)\NVIDIA Corporation\NvContainer\nvcontainer.exe
    Memory Usage 22 MB
    Peak Memory Usage 42 MB
    NVDisplay.Container.exe
    Process ID 1784
    User SYSTEM
    Domain NT AUTHORITY
    Path C:\Program Files\NVIDIA Corporation\Display.NvContainer\NVDisplay.Container.exe
    Memory Usage 12 MB
    NVIDIA Web Helper.exe
    Process ID 1320
    User john_
    Path C:\Program Files (x86)\NVIDIA Corporation\NvNode\NVIDIA Web Helper.exe
    Memory Usage 1.04 MB
    NvTelemetryContainer.exe
    Process ID 3836
    User NETWORK SERVICE
    Domain NT AUTHORITY
    Path C:\Program Files (x86)\NVIDIA Corporation\NvTelemetry\NvTelemetryContainer.exe
    Memory Usage 12 MB
    nvtray.exe
    Process ID 9836
    User john_
    Path C:\Program Files\NVIDIA Corporation\Display\nvtray.exe
    Memory Usage 12 MB
    nvxdsync.exe
    Process ID 2992
    User SYSTEM
    Domain NT AUTHORITY
    Path C:\Program Files\NVIDIA Corporation\Display\nvxdsync.exe
    Memory Usage 23 MB
    PhoneTray.exe
    Process ID 10468
    User john_
    Path C:\Program Files (x86)\Traysoft\PhoneTray\PhoneTray.exe
    Memory Usage 14 MB
    PresentationFontCache.exe
    Process ID 7316
    User LOCAL SERVICE
    Domain NT AUTHORITY
    Path C:\Windows\Microsoft.NET\Framework64\v3.0\WPF\PresentationFontCache.exe
    Memory Usage 19 MB
    Peak Memory Usage 19 MB
    PRSvc.exe
    Process ID 12636
    User SYSTEM
    Domain NT AUTHORITY
    Path C:\Program Files\Dell\Dell Product Registration\PRSvc.exe
    Memory Usage 65 MB
    Peak Memory Usage 66 MB
    RAVBg64.exe
    Process ID 3216
    User SYSTEM
    Domain NT AUTHORITY
    Path C:\Program Files\Realtek\Audio\HDA\RAVBg64.exe
    Memory Usage 15 MB
    RAVBg64.exe
    Process ID 3272
    User SYSTEM
    Domain NT AUTHORITY
    Memory Usage 14 MB
    RAVBg64.exe
    Process ID 10608
    User john_
    Memory Usage 748 KB
    RAVBg64.exe
    Process ID 2296
    User john_
    Memory Usage 18 MB
    RegSrvc.exe
    Process ID 3864
    User SYSTEM
    Domain NT AUTHORITY
    Path C:\Program Files\Common Files\Intel\WirelessCommon\RegSrvc.exe
    Memory Usage 9.36 MB
    Peak Memory Usage 9.49 MB
    RtkAudioService64.exe
    Process ID 2688
    User SYSTEM
    Domain NT AUTHORITY
    Path C:\Program Files\Realtek\Audio\HDA\RtkAudioService64.exe
    Memory Usage 7.23 MB
    Peak Memory Usage 7.67 MB
    RtkNGUI64.exe
    Process ID 1648
    User john_
    Path C:\Program Files\Realtek\Audio\HDA\RtkNGUI64.exe
    Memory Usage 14 MB
    RuntimeBroker.exe
    Process ID 8700
    User john_
    Path C:\Windows\System32\RuntimeBroker.exe
    Memory Usage 47 MB
    Peak Memory Usage 63 MB
    SearchIndexer.exe
    Process ID 8584
    User SYSTEM
    Domain NT AUTHORITY
    Path C:\Windows\System32\SearchIndexer.exe
    Memory Usage 42 MB
    Peak Memory Usage 46 MB
    SearchUI.exe
    Process ID 8280
    User john_
    Path C:\Windows\SystemApps\Microsoft.Windows.Cortana_cw5n1h2txyewy\SearchUI.exe
    Memory Usage 153 MB
    Peak Memory Usage 178 MB
    SecurityHealthService.exe
    Process ID 3852
    User SYSTEM
    Domain NT AUTHORITY
    Path C:\Windows\System32\SecurityHealthService.exe
    Memory Usage 15 MB
    services.exe
    Process ID 988
    User SYSTEM
    Domain NT AUTHORITY
    Path C:\Windows\System32\services.exe
    Memory Usage 9.91 MB
    SettingSyncHost.exe
    Process ID 784
    User john_
    Path C:\Windows\System32\SettingSyncHost.exe
    Memory Usage 3.66 MB
    Peak Memory Usage 98 MB
    ShellExperienceHost.exe
    Process ID 8076
    User john_
    Path C:\Windows\SystemApps\ShellExperienceHost_cw5n1h2txyewy\ShellExperienceHost.exe
    Memory Usage 69 MB
    Peak Memory Usage 70 MB
    sihost.exe
    Process ID 7260
    User john_
    Path C:\Windows\System32\sihost.exe
    Memory Usage 24 MB
    SkypeHost.exe
    Process ID 3540
    User john_
    Path C:\Program Files\WindowsApps\Microsoft.SkypeApp_11.18.614.0_x64__kzf8qxf38zg5c\SkypeHost.exe
    Memory Usage 29 MB
    Peak Memory Usage 85 MB
    smartscreen.exe
    Process ID 9884
    User john_
    Path C:\Windows\System32\smartscreen.exe
    Memory Usage 20 MB
    Peak Memory Usage 20 MB
    smss.exe
    Process ID 556
    User SYSTEM
    Domain NT AUTHORITY
    Path C:\Windows\System32\smss.exe
    Memory Usage 1.13 MB
    Peak Memory Usage 1.17 MB
    Speccy64.exe
    Process ID 9604
    User john_
    Path C:\Program Files\Speccy\Speccy64.exe
    Memory Usage 29 MB
    Peak Memory Usage 29 MB
    spoolsv.exe
    Process ID 2528
    User SYSTEM
    Domain NT AUTHORITY
    Path C:\Windows\System32\spoolsv.exe
    Memory Usage 16 MB
    SupportAssistAgent.exe
    Process ID 12840
    User SYSTEM
    Domain NT AUTHORITY
    Path C:\Program Files\Dell\SupportAssistAgent\bin\SupportAssistAgent.exe
    Memory Usage 85 MB
    Peak Memory Usage 86 MB
    svchost.exe
    Process ID 1880
    User LOCAL SERVICE
    Domain NT AUTHORITY
    Path C:\Windows\System32\svchost.exe
    Memory Usage 6.77 MB
    Peak Memory Usage 7.06 MB
    svchost.exe
    Process ID 2256
    User SYSTEM
    Domain NT AUTHORITY
    Memory Usage 7.93 MB
    Peak Memory Usage 8.26 MB
    svchost.exe
    Process ID 3728
    User SYSTEM
    Domain NT AUTHORITY
    Memory Usage 24 MB
    svchost.exe
    Process ID 596
    User SYSTEM
    Domain NT AUTHORITY
    Memory Usage 3.77 MB
    Peak Memory Usage 3.90 MB
    svchost.exe
    Process ID 752
    User SYSTEM
    Domain NT AUTHORITY
    Memory Usage 24 MB
    svchost.exe
    Process ID 2220
    User LOCAL SERVICE
    Domain NT AUTHORITY
    Memory Usage 7.41 MB
    Peak Memory Usage 7.80 MB
    svchost.exe
    Process ID 1160
    Domain NT AUTHORITY
    Memory Usage 12 MB
    svchost.exe
    Process ID 1204
    User SYSTEM
    Domain NT AUTHORITY
    Memory Usage 6.63 MB
    Peak Memory Usage 6.77 MB
    svchost.exe
    Process ID 1400
    User SYSTEM
    Domain NT AUTHORITY
    Peak Memory Usage 9.61 MB
    svchost.exe
    Process ID 1464
    User SYSTEM
    Domain NT AUTHORITY
    Memory Usage 15 MB
    svchost.exe
    Process ID 1508
    User SYSTEM
    Domain NT AUTHORITY
    Memory Usage 10 MB
    svchost.exe
    Process ID 1548
    User SYSTEM
    Domain NT AUTHORITY
    Memory Usage 8.27 MB
    Peak Memory Usage 8.36 MB
    svchost.exe
    Process ID 1716
    User SYSTEM
    Domain NT AUTHORITY
    Memory Usage 5.86 MB
    Peak Memory Usage 6.08 MB
    svchost.exe
    Process ID 2976
    User SYSTEM
    Domain NT AUTHORITY
    Memory Usage 7.24 MB
    Peak Memory Usage 7.24 MB
    svchost.exe
    Process ID 1836
    User SYSTEM
    Domain NT AUTHORITY
    Memory Usage 5.76 MB
    Peak Memory Usage 5.94 MB
    svchost.exe
    Process ID 1888
    User LOCAL SERVICE
    Domain NT AUTHORITY
    Memory Usage 11 MB
    svchost.exe
    Process ID 1896
    User LOCAL SERVICE
    Domain NT AUTHORITY
    Memory Usage 7.74 MB
    Peak Memory Usage 7.98 MB
    svchost.exe
    Process ID 1904
    User LOCAL SERVICE
    Domain NT AUTHORITY
    Memory Usage 11 MB
    svchost.exe
    Process ID 1912
    User LOCAL SERVICE
    Domain NT AUTHORITY
    Memory Usage 22 MB
    Peak Memory Usage 26 MB
    svchost.exe
    Process ID 1996
    User LOCAL SERVICE
    Domain NT AUTHORITY
    Memory Usage 19 MB
    Peak Memory Usage 22 MB
    svchost.exe
    Process ID 3332
    User LOCAL SERVICE
    Domain NT AUTHORITY
    Memory Usage 8.89 MB
    Peak Memory Usage 9.26 MB
    svchost.exe
    Process ID 4780
    User SYSTEM
    Domain NT AUTHORITY
    Memory Usage 6.10 MB
    Peak Memory Usage 6.17 MB
    svchost.exe
    Process ID 2168
    User LOCAL SERVICE
    Domain NT AUTHORITY
    Memory Usage 9.63 MB
    Peak Memory Usage 9.79 MB
    svchost.exe
    Process ID 6108
    User LOCAL SERVICE
    Domain NT AUTHORITY
    Memory Usage 7.97 MB
    Peak Memory Usage 8.06 MB
    svchost.exe
    Process ID 6064
    User LOCAL SERVICE
    Domain NT AUTHORITY
    Memory Usage 6.34 MB
    Peak Memory Usage 6.55 MB
    svchost.exe
    Process ID 2044
    User SYSTEM
    Domain NT AUTHORITY
    Memory Usage 8.02 MB
    Peak Memory Usage 8.25 MB
    svchost.exe
    Process ID 6004
    User SYSTEM
    Domain NT AUTHORITY
    Memory Usage 16 MB
    svchost.exe
    Process ID 5920
    User LOCAL SERVICE
    Domain NT AUTHORITY
    Memory Usage 15 MB
    svchost.exe
    Process ID 7288
    User john_
    Memory Usage 19 MB
    svchost.exe
    Process ID 5580
    User SYSTEM
    Domain NT AUTHORITY
    Memory Usage 6.86 MB
    Peak Memory Usage 6.88 MB
    svchost.exe
    Process ID 3108
    Domain NT AUTHORITY
    Memory Usage 7.78 MB
    svchost.exe
    Process ID 6592
    User LOCAL SERVICE
    Domain NT AUTHORITY
    Memory Usage 11 MB
    svchost.exe
    Process ID 6572
    User SYSTEM
    Domain NT AUTHORITY
    Memory Usage 21 MB
    svchost.exe
    Process ID 9052
    User LOCAL SERVICE
    Domain NT AUTHORITY
    Memory Usage 8.67 MB
    Peak Memory Usage 8.70 MB
    svchost.exe
    Process ID 5540
    User LOCAL SERVICE
    Domain NT AUTHORITY
    Memory Usage 9.66 MB
    svchost.exe
    Process ID 5500
    User LOCAL SERVICE
    Domain NT AUTHORITY
    Memory Usage 12 MB
    svchost.exe
    Process ID 5492
    User LOCAL SERVICE
    Domain NT AUTHORITY
    Memory Usage 8.62 MB
    Peak Memory Usage 8.79 MB
    svchost.exe
    Process ID 6952
    User LOCAL SERVICE
    Domain NT AUTHORITY
    Memory Usage 21 MB
    svchost.exe
    Process ID 3064
    User john_
    Memory Usage 37 MB
    Peak Memory Usage 39 MB
    svchost.exe
    Process ID 3812
    User SYSTEM
    Domain NT AUTHORITY
    Memory Usage 5.55 MB
    Peak Memory Usage 5.72 MB
    svchost.exe
    Process ID 7448
    User SYSTEM
    Domain NT AUTHORITY
    Memory Usage 17 MB
    Peak Memory Usage 18 MB
    svchost.exe
    Process ID 4508
    User LOCAL SERVICE
    Domain NT AUTHORITY
    Memory Usage 5.38 MB
    Peak Memory Usage 5.60 MB
    svchost.exe
    Process ID 4468
    User SYSTEM
    Domain NT AUTHORITY
    Memory Usage 19 MB
    svchost.exe
    Process ID 7836
    User SYSTEM
    Domain NT AUTHORITY
    Memory Usage 5.56 MB
    Peak Memory Usage 5.77 MB
    svchost.exe
    Process ID 7512
    User SYSTEM
    Domain NT AUTHORITY
    Memory Usage 18 MB
    svchost.exe
    Process ID 7348
    User john_
    Memory Usage 23 MB
    Peak Memory Usage 24 MB
    svchost.exe
    Process ID 4416
    User SYSTEM
    Domain NT AUTHORITY
    Memory Usage 9.14 MB
    Peak Memory Usage 9.41 MB
    svchost.exe
    Process ID 13236
    User LOCAL SERVICE
    Domain NT AUTHORITY
    Memory Usage 12 MB
    svchost.exe
    Process ID 2968
    User SYSTEM
    Domain NT AUTHORITY
    Memory Usage 15 MB
    svchost.exe
    Process ID 3060
    User SYSTEM
    Domain NT AUTHORITY
    Memory Usage 41 MB
    Peak Memory Usage 82 MB
    svchost.exe
    Process ID 2800
    User LOCAL SERVICE
    Domain NT AUTHORITY
    Memory Usage 6.16 MB
    Peak Memory Usage 6.34 MB
    svchost.exe
    Process ID 3908
    User LOCAL SERVICE
    Domain NT AUTHORITY
    Memory Usage 16 MB
    svchost.exe
    Process ID 3900
    User LOCAL SERVICE
    Domain NT AUTHORITY
    Memory Usage 7.00 MB
    Peak Memory Usage 7.36 MB
    svchost.exe
    Process ID 2792
    User LOCAL SERVICE
    Domain NT AUTHORITY
    Memory Usage 13 MB
    svchost.exe
    Process ID 2712
    Domain NT AUTHORITY
    Memory Usage 8.82 MB
    Peak Memory Usage 8.89 MB
    svchost.exe
    Process ID 8848
    User SYSTEM
    Domain NT AUTHORITY
    Memory Usage 11 MB
    svchost.exe
    Process ID 2652
    User SYSTEM
    Domain NT AUTHORITY
    Memory Usage 6.32 MB
    Peak Memory Usage 6.56 MB
    svchost.exe
    Process ID 3024
    User SYSTEM
    Domain NT AUTHORITY
    Memory Usage 11 MB
    svchost.exe
    Process ID 2580
    User SYSTEM
    Domain NT AUTHORITY
    Memory Usage 10 MB
    svchost.exe
    Process ID 2508
    User LOCAL SERVICE
    Domain NT AUTHORITY
    Memory Usage 9.45 MB
    Peak Memory Usage 9.62 MB
    svchost.exe
    Process ID 2420
    Domain NT AUTHORITY
    Memory Usage 12 MB
    svchost.exe
    Process ID 3828
    User SYSTEM
    Domain NT AUTHORITY
    Memory Usage 19 MB
    svchost.exe
    Process ID 3820
    User SYSTEM
    Domain NT AUTHORITY
    Memory Usage 15 MB
    svchost.exe
    Process ID 1612
    User SYSTEM
    Domain NT AUTHORITY
    Memory Usage 5.87 MB
    Peak Memory Usage 6.03 MB
    svchost.exe
    Process ID 3800
    User SYSTEM
    Domain NT AUTHORITY
    Memory Usage 22 MB
    svchost.exe
    Process ID 3792
    User SYSTEM
    Domain NT AUTHORITY
    Memory Usage 108 MB
    Peak Memory Usage 124 MB
    svchost.exe
    Process ID 3784
    Domain NT AUTHORITY
    Memory Usage 9.01 MB
    Peak Memory Usage 9.03 MB
    svchost.exe
    Process ID 3776
    User SYSTEM
    Domain NT AUTHORITY
    Memory Usage 7.29 MB
    Peak Memory Usage 7.68 MB
    svchost.exe
    Process ID 3768
    Domain NT AUTHORITY
    Memory Usage 13 MB
    svchost.exe
    Process ID 2396
    User LOCAL SERVICE
    Domain NT AUTHORITY
    Memory Usage 12 MB
    svchost.exe
    Process ID 2264
    User LOCAL SERVICE
    Domain NT AUTHORITY
    Memory Usage 7.47 MB
    System
    Process ID 4
    Memory Usage 2.99 MB
    Peak Memory Usage 8.04 MB
    System Idle Process
    Process ID 0
    SystemSettings.exe
    Process ID 11652
    User john_
    Path C:\Windows\ImmersiveControlPanel\SystemSettings.exe
    Memory Usage 45 MB
    Peak Memory Usage 59 MB
    taskhostw.exe
    Process ID 7452
    User john_
    Path C:\Windows\System32\taskhostw.exe
    Memory Usage 21 MB
    unsecapp.exe
    Process ID 10884
    User john_
    Path C:\Windows\System32\wbem\unsecapp.exe
    Memory Usage 6.79 MB
    Peak Memory Usage 6.79 MB
    unsecapp.exe
    Process ID 6336
    User SYSTEM
    Domain NT AUTHORITY
    Memory Usage 6.90 MB
    Peak Memory Usage 6.95 MB
  • Chris Wright
    July 4, 2017 at 11:57 am
    you need to start from scratch.
    for example, did you ever change the old graphics drivers?
    is nvidia control panel set to use premiere.exe ‘always’ while loaded?
    have you done a stress test on your components with passmark95 to detect overheating and damaged parts?
    at this point, I’d wipe the OS, reinstall only necessary drivers and check temperatures as overheating can cause software failure.
  • Andy Patterson
    July 4, 2017 at 6:08 pm
    You might want to wipe and reload everything. It sucks but sometimes that is the only thing that works.
  • Duke Sweden
    July 4, 2017 at 11:39 pm
    I did the next best thing. I brought it back (it was a previous return, now I know why), and got the XPS 8910 which just went on sale for only 50 bucks more than I paid for the 8910. Currently setting it all up. Sorry about that loooooong list of crap before, I had no idea when I pasted it and posted. Anyway, I’ll let you know how this one is going. So far it’s not seeing my 3rd HDD and none of my USB ports work except the ones in back that my keyboard and mouse are plugged into, grrrrr….
  • Duke Sweden
    July 5, 2017 at 1:48 am
    btw, this one is i7 7700 build. It’s running a lot smoother, but I can’t get one HDD to show up, and it’s the one I saved all my stuff on before I wiped the other PC. Aggravating!!! Plus the front USB ports don’t work. Oh well, time to watch the fireworks. The ones in my head, that is!!!
  • Chris Wright
    July 5, 2017 at 3:50 am
    Is the hd motor spinning? Are both sata and power plugged in?
    Is sata enabled in bios?
    Is the usb header port plugged into the motherboard?
  • Brent Marginet
    July 5, 2017 at 7:07 am
    Have you gone into the Device Manager to see if there are any Drivers that aren’t installed.
    You would see an Icon that looks like a question mark or a triangle with an exclamation mark in it.
    Dell has really great support and drivers are generally very easy to find on there site.
  • Duke Sweden
    July 5, 2017 at 9:41 am
    As far as the USB ports, the wires inside this thing are so short that when you lift the power supply module, which you’re supposed to do to install a graphics card, it unplugged the USB ports. That’s working now. Still trying to figure out the HDD. Everything is plugged in tight, and I reset the BIOS to default, as suggested by Dell, previously as a “fix” for the USB port problem. BTW, the HDD doesn’t even show up under disk management, so at this point I have no idea what the problem is. Once I wake up I’ll play with it again. I have the cover off anyway since I’m expecting my RAM chip tomorrow.
