Activity › Forums › Adobe Premiere Pro › Suddenly PP2 can’t find DVD burner
Posted by Dan Plonsker on October 11, 2007 at 8:29 amAll was OK last week.
I have installed WMP11. Can this be the problem?
Any way to fix it?
ThanksDan Plonsker replied 18 years, 11 months ago 2 Members · 4 Replies -
Mike Velte
October 11, 2007 at 9:55 amTry a “System Restore” to just before the last time it worked.
Dan Plonsker
October 11, 2007 at 10:23 amThanks Mike, but this would be before (I guess)I installed wmp11. wouldn’t that remove it too?
Mike Velte
October 11, 2007 at 11:45 amThis may disable WMP 11, but if it fixed your burner problem, then you will know who the culprit is. You can always reinstall wmp 11.
Maybe it is the order of installations. Try reinstalling Premiere after installing wmp 11.
I have 11 on one PC and Premiere 2 sees my burner. -
Dan Plonsker
October 11, 2007 at 11:56 amYa, I thought about reinstalling premiere to fix the problem, but hoped for a less drastic solution… 🙂
Thanks a lot.
