Activity › Forums › Adobe Photoshop › Suddenly my Brushes and Eraser are not working properly
  • Anuradha Joshi
    January 21, 2011 at 4:46 am
    Check if you are using Tablets , because the same problem I also faced , but when I remove Bamboo tool , eraser tool is perfectly working ..
    check it out if possible.
  • Joanne Simoneau
    January 25, 2011 at 8:25 pm
    Thank you. I was going crazy. I too, have the writing pad installed and when I unplugged the usb from the pad… my brushes worked again. Thank you, I was ready to pull my hair out when my paintshop brushes wouldnt work!
  • Jose Alvarado
    December 6, 2011 at 11:04 am
    DUDE AMAZING!! YOU SOLVED MY PROBLEM !!! IT WAS THE MODE: BRUSH that did it! I almost went crazy bananas there…
  • Necole Cameron
    December 11, 2011 at 10:15 pm
    Thanks! You saved my life and helped me make deadline!
    ~May the force be with you.
  • David Ramirez
    December 26, 2011 at 6:41 am
    Also make sure your layer is not a vector – then the eraser tool will be blocked (crossed circle instead of the tool at the mouse pointer). Choose Rasterize from the layer menu – then the tool will work normally.
  • Renate Hovius
    May 31, 2012 at 3:31 pm
    hi, had the same problem, thankfully I found this message and problem solved 🙂 thank you
  • Meir Sussman
    January 4, 2015 at 10:22 pm
    Dear Vincent,
    IT IS 2015 already and your post still saves people from Photoshop CS6 DROWNING :-)))
    Thanks a lot.
  • Calvin De beverly
    January 9, 2015 at 9:40 pm
    Using Painter 15 and my pens stopped working. Read this post, reset the tool (have to figure that is why they put it there just to cover “unforeseen” errors) and back to work. Thanks.
  • Heather Hartin
    May 5, 2015 at 1:20 pm
    I think my Photoshop is different from your version. I don’t see the two “tool” options that you suggested to gain access to erasing again. By the way, I did finally notice that my eraser works until I decide to move anything or do anything else with the page, so I’ve learned to try and erase everything that I think I will need to before I do anything else. Unfortunately, there’s one page that has been permanently changed, rather than layered, and I don’t know how to enable the eraser. Thank you for your time and help!
  • Ray Greenberg
    June 15, 2015 at 7:19 pm
    Yo, reset all tools did it for me! Thanks a bunch. I was doing all sorts of work arounds till I checked here ;–)
Page 2 of 3
