Activity Forums Adobe Premiere Pro Suddenly I can’t play past my out point in my source monitor
  • Suddenly I can’t play past my out point in my source monitor
    Posted by Kristopher Wile on August 31, 2014 at 11:13 pm
    I’ve been working on a demo reel for a directing client, playing through their material in fast forward and clipping out bits I want to use for later using my in and out points (I drag them down into a sequence I created to set them aside). Suddenly however, I am no longer able to fast forward past my out point in the source monitor. It just loops between my in and out points and I can’t figure out how that happened or how to disable it. Now I have to constantly reset my out point every time I want to keep moving forward through the source material.
    Anybody have a solution?
    Andrew Kimery replied 12 years ago 2 Members · 2 Replies
  • Kristopher Wile
    September 1, 2014 at 12:07 am
    Figured it out – somehow my loop setting had been enabled. Turned it off and all is fine now.
  • Andrew Kimery
    September 1, 2014 at 1:41 am
    I’m not in front of PPro right now but it sounds like you accidentally turned on the play loop in-to-out feature. There should be a menu setting to toggle it on/off some place.
