Activity Forums Adobe After Effects Suddenly Ai File won’t save after being imported in Ae
  • Suddenly Ai File won’t save after being imported in Ae
    Posted by Syma Kahil on June 23, 2020 at 2:10 pm
    So I’m working on a project on After Effects with illustrations from an Illustrator file. I compile all the graphics I need on multiple layers in Illustrator and have that one Illustrator file imported into my project. 90% of the times I have no issues…
    I usually go back to the illustrator file to make small adjustments and save as and it updates automatically on After Effects. But sometimes randomly, the Ai. file will lock and I get this error :
    “Can’t save the illustration. The file may be read-only, or the file is in use by another application, or you do not have required permissions. Please save the document with a different name, or in a different folder or directory. ID: -54”
    The file won’t even save if I quit after effects. It’s time-consuming to rename the file and re-link the layers in Ae.
    Does anyone know why this is happening and how I can fix it?
    I’m on Windows 10, Ae 2019, Illustrator 2020.
    Syma Kahil replied 6 years, 2 months ago 1 Member · 0 Replies
  • 0 Replies
