Activity Forums Apple Final Cut Pro Legacy Sudden Electric Discharge + KG-core plugin error message
  • Sudden Electric Discharge + KG-core plugin error message
    Posted by Anastasia Cipolla on March 11, 2011 at 5:23 pm
    Hi All,
    I’m experiencing a suddenly electric discharge with ‘poppin’ sound, while working ona huge FCP project using several different codecs (H264, Pro Res 422, color clips).
    Then, I tried to log out fcp and an error message relating to the KG-core plugin came up.
    In terms of audio I’ve imported recently the waw file from the composer and some new aiff tracks.
    I recently reinstalled my operating system.
    It seems like a huge audio crash, can someone help? Every suggestion will be really appreciate! Thank you so much:)
    MacBookPro
    2.66 GHz Intel Core 2 Duo
    4GB 1067 MHz DDE3
    Mac OS X 10.6.6
    James Mortner replied 15 years, 6 months ago 2 Members · 1 Reply
  • James Mortner
    March 14, 2011 at 9:57 am
    First step, trash your preferences in your user folder as well as cached thumbnails and waveform files. These are in your final cut scratch directory.
    Power down and reboot. If you have the same message you may need to repair permissions on your drive…
    Hope this helps
