Activity › Forums › Adobe Premiere Pro › Sudden aspect change on timeline
  • Sudden aspect change on timeline
    Posted by Cam on January 16, 2006 at 8:38 pm
    I am working in dv widescreen aspect. I will be editing footage and all of the sudden the next time i go back to the clip on the timeline after a preview render, it is squeezed in on the sides. Kind of like a 4/3 image centered in a 16/9 aspect. Premiere is squeezing my 16/9 into 4/3 to make this happen. Other clips around that clip on the timeline do not have the same problem. So i try to delete the clip from the timeline and make a new cut on that clip in the source monitor. Once i import it back to the timeline sequence it retains its correct demensions until I render a new preview, then it switches back to the same problem again. I found that if I add a video effect to the footage it retains the correct 16:9 format again. I also have tried to delete all rendered previews, same things happens. All is fine until i render a new preview. I have search all over for a fix to this problem, but have not found the answere.
    Seems like i am not the only one with this issue, see below.
    https://forums.creativecow.net/cgi-bin/new_read_post.cgi?forumid=3&postid=857378
    Cam replied 20 years, 8 months ago 1 Member · 0 Replies
  • 0 Replies
