Activity Forums Adobe After Effects Sucking someone through a funnel…
  • Sucking someone through a funnel…
    Posted by Rusty Bridges on June 22, 2006 at 1:06 pm
    What im trying to achieve is a person who is like sucked thru a sort of black hole…his normla size would sort off shrink as he enters the funnel by the narrow hole
    Any suggestions are very welcomed!
    Goldman replied 20 years, 2 months ago 3 Members · 2 Replies
  • Graham Quince
    June 22, 2006 at 4:29 pm
    I’d check out the bezier warp filter.
    You’d need to pre-comp your cut out person, moving down the screen, then apply the filter in the main comp. Drag the target around to get an idea of how it works. But it should be fairly straight forward.
    Graham
    https://www.quinceweb.com – web design
    https://www.shiveringcactus.bravehost.com – Free FX for amateur films
  • Goldman
    June 22, 2006 at 11:32 pm
    Try effect > distort > liquify
    Keyframe the original, then smear a the image towards the funnel and ad a keyframe, then repeat.
    This is not the most sophisticated method
