Activity › Forums › Apple Final Cut Pro › Subtitles (open captions) in FCPX
  • Subtitles (open captions) in FCPX
    Posted by Andreas Kiel on June 30, 2015 at 7:41 am
    Hello,
    I’ve released new versions of X-Titles (Import, Export) with several new features and fixes.
    There are some importers/exporters like srt2X or sugarFX subtitles. While the sugarFX is easy to use and has several import/export options srt2X is very limited.
    Both of them don’t support style settings which are supplied to the source. Styles are also not supported on export.
    X-Titles tries to close this gap. The export additionally supports DCP which can be important for documentaries which go to festival screening or even if they are used commercially.
    So you might give it a try.
    https://www.spherico.com/filmtools/TitleExchange/XTI/index.html
    https://www.spherico.com/filmtools/TitleExchange/XTE/index.html
    – Andreas
    Spherico
    “He who fights with monsters should be careful lest he thereby
    become a monster. And if thou gaze long into an abyss, the abyss will
    also gaze into thee.” – Friedrich Nietzsche, Beyond Good and Evil
    Andreas Kiel replied 11 years, 2 months ago 1 Member · 0 Replies
  • 0 Replies
