Activity Forums VEGAS Pro Subtitles cause error upon rendering in DVDA
  • Subtitles cause error upon rendering in DVDA
    Posted by Keith Sorbo on April 15, 2005 at 6:19 am
    I have a 23 minute video (MainConcept1 NTSC) and accompanying wave file (PCM)
    I have imported both into DVD Architect 2.0. I did the Prepare DVD process with no problems.
    Now I add about 10-15 subtitles in a subtitle track. When I Prepare DVD, the render process goes all the way to 100% as if it is finished, then gives an error message, something to the effect that what I am trying to do is too complex for the DVD format!
    Any ideas? I need to put far more subtitles into the system. (Have only done 2 of 23 minutes). Is there a setting I am missing?
    Keith
    Keith Sorbo replied 21 years, 4 months ago 2 Members · 4 Replies
  • Keith Sorbo
    April 15, 2005 at 11:28 pm
    Followup to my first message:
    The exact working of the error message is as follows:
    “An error occured while writing a file.
    The sub-picture or menu highlights are too complex and exceed the DVD specification.”
    The original DVD I was preparing was in the single movie format. Clearly there were no sub-pictures or menu highlights. Through experimentation, I found that if I created a menu and then included my movie, I didn’t get the error messages any longer!
    Go figure!
  • Edward Troxel
    April 16, 2005 at 2:07 am
    One of your subtitles is too big. Check out all your subtitles.
    Edward Troxel
    JETDV Scripts
  • Keith Sorbo
    April 16, 2005 at 6:32 am
    What is too big?
    I used exactly the same subtitles but ran it with the movie as a menu item (not single movie dvd), and it works just fine?
  • Keith Sorbo
    April 24, 2005 at 12:48 pm
    As a followup, I have discovered the solution to the problem I originally posted.
    Upgrade DVD Architect to at least 2.0a. (The current upgrade version is 2.0b).
    Starting at 2.0a, DVDA checks subtitles prior to preparing and points out subtitles with problems.
    I would have NEVER discovered the problem by trial and error. The offending subtitle was formatted the same as others and had 2 lines with about 10 words!
    After upgrading, the offending subtitle was pointed out, I deleted it and created a new one with the same content and everything was just fine.
    Keith
