Activity › Forums › Adobe After Effects › subtitle with black square background behind text
  • subtitle with black square background behind text
    Posted by Aqeel Sami on May 16, 2012 at 7:09 pm
    I want to make a subtitle or a text at the 3rd lower part of a footage but I need to make the black box behind the text exactly and i want that box to be the same size of the text exactly like subtitles on movies. is there comments ?
    Aqeel Sami replied 14 years, 4 months ago 2 Members · 2 Replies
  • Andy Galloway
    May 16, 2012 at 10:35 pm
    Hi mate,
    I don’t think there is a built in effect that will do this.
    However I achieved an automated result by doing the following.
    Creating another layer of black text behind the white subtitle text.
    Make the black text slightly bigger than the white in the character palette and make sure the text baseline is set in the middle.
    Pickwhip the source of the black bg text to the original white text.
    Apply a fast blur to the black bg text set at 250 and turning on repeated edge pixels.
    Apply a mosaic effect turned up to 1000 horizontal and 500 vertical.
    Then finally apply a black light sweep set to maximum intensity and composite mode. You will need to duplicate this effect about 4 times.
    That’s it… sorry if that is a bit confusing it was a bit of trial and error. There maybe a really simple way but I have not heard of one.
    I’ve uploaded my project for you anyway mate.
    https://f1.creativecow.net/4154/subtitle-bg
    Good luck
  • Aqeel Sami
    May 18, 2012 at 2:30 pm
    Thanks alot…it was wonderful..
