Activity › Forums › Apple Final Cut Pro Legacy › Submit button won’t appear in Compressor
Posted by Victor Vazquez on June 16, 2012 at 8:21 pmHello all,
When I send a FCP project to Compressor, the submit button remains faded and I am not able to convert my projects. I have read that a possible solution is to reinstall FCS, but I’m afraid I will lose all the work I’ve done on projects in FCP. What are the possible solutions to get Compressor back and running again?
Thank you,
VictorCristina Loyola replied 13 years, 1 month ago 4 Members · 8 Replies -
Jason Brown
June 16, 2012 at 9:57 pmIt’s a Qmaster vs compressor version issue. 3.5 vs 3.53 they have to match
Victor Vazquez
June 16, 2012 at 10:55 pmThank you! How would I go about resolving the issue?
-Victor
Jason Brown
June 16, 2012 at 11:26 pmI’m guessing u put fcpx on ur machine? It moved all old fcs apps into a subfolder and the updated can’t find them. There is a post I was a part of awhile ago on here…search for it.
Victor Vazquez
June 17, 2012 at 7:15 amI actually just found out that both versions match (3.5.3). I’m not sure what the problem is.
Michael Gissing
June 17, 2012 at 8:15 amTry to export a self contained quicktime movie using current settings. Then take that QT file into Compressor and try again. The problem may be in FCP or Compressor but this way we can isolate the issue.
If you can’t submit anything in Compressor then it might be time to try Digital Rebellions excellent Preference Manager which allows you to delete preferences in FCP and Compressor. Often weird problem can be corrupted preference files in various software.
Victor Vazquez
June 17, 2012 at 8:23 amThank you. I removed Compressor then reinstalled it, and that seems to have solved the problem.
-Victor
Cristina Loyola
August 20, 2013 at 11:08 pmAnother solution, without the need of re-installing:
https://www.digitalrebellion.com/compressorrepair/download.html
