Activity Forums Maxon Cinema 4D Submarine bursting out of ocean
  • Submarine bursting out of ocean
    Posted by Tony Marcuccino on December 22, 2010 at 3:28 pm
    Hello guys looking for a solid answer to a liquid question. How would I create a submarine bursting out
    from underwater in C4D. I have already created the sub but it seems that the ability to create realistic
    ocean splash is driving me crazy. I have also created the ocean with a plane and some textures. Im relatively new to C4D and Im also using Zbrush to model. Im trying to create an arial view of this as well. Is there a way to simulate a very specific liquid splash natively in C4D with Mograph?
    Tony Marcuccino replied 15 years, 8 months ago 2 Members · 2 Replies
  • Michael Szalapski
    December 29, 2010 at 9:45 pm
    I’m brand new to the world of Cinema 4d, but I do recall seeing a tutorial somewhere (Lynda.com, I believe) that created a splash with particles and a metaball object.
    As I recall, it suggests you get a decent-looking splash movement with your particles. Use spheres for your particles. Parent the emitter to the metaball object and tweak the settings (raise the hull value and lower the subdivisions). The metaball will look very different in the render than it does in the editor window so check it in a render.
    – The Great Szalam
    (The ‘Great’ stands for ‘Not So Great, in fact, Extremely Humble’)
  • Tony Marcuccino
    December 30, 2010 at 3:57 pm
    Thanks… I’ll look for the tutorial and give it a try!
