Activity › Forums › Adobe Premiere Pro › Subliminal Messages.
Posted by Headofred on January 21, 2007 at 6:33 pmI’m doing an experiment about subliminal messages in Premier Pro. I wan’t to make some clips/titles about 3 frame to about 1/2 a frame long. How could I do this?
Calum Readhead
Bouke Vahl replied 19 years, 7 months ago 4 Members · 3 Replies -
Steven L. gotz
January 21, 2007 at 10:10 pmHalf of a frame is impossible. You get a frame, or more. Less than one frame is zero. No fractions allowed.
Except if you mean that only half of a frame would have the message while the rest of the frame was normal?
It is simple enough to make a title and put it over the video. Right click on the title in the sequence and set the duration to 1, 2 or 3 frames and see if it works for you. I doubt you will be happy. Most subliminal message have to do with quick messages, yes. But they are also in colors that closely match the video. It is not all that simple.
Steven
https://www.stevengotz.com -
Blast1
January 22, 2007 at 6:20 amThere have been many attempts at using subliminal messages to influence people with little effect, from advertising to behavior modification, popular are self-help tapes, the link below sumerises it.
https://en.wikipedia.org/wiki/Subliminal_message
Bouke Vahl
January 22, 2007 at 10:07 amHalf a frame is very well possible if you have an interlaced show.
Make a still in photoshop of white and black lines, WITHOUT ANTI ALIASING!, just one pixel horizontal.
Use that as a key signal on one frame. Voila, one field show, other field subliminal message.I already feel the urge for a coke coming up…
Bouke
http://www.videoToolShed.com
smart tools for video pro’s
