Activity Forums Apple Final Cut Pro Legacy Subcliping issues
  • Subcliping issues
    Posted by Andres Rios on July 27, 2011 at 2:42 am
    Hi I’m having issues syncing audio to picture and making a subclip. I sync audio to video in the timeline according to sound slate, I link them up then load the clip in the viewer
    “make subclip”. This works fine.
    The problem is when I try and sync up the next clip. I’m working off a sequence I called ‘sync’ and when I delete the clips I just synced up I get this message “Sequence Error: Unable to add clip to sequence. Possible media limits problem in clip or sequence” . I cant add clips to the time line or delete the one I already have. So basically, for every new clip I want to sync I have to create a new sequence and this get annoying after a while because I’m sure there is way around this.
    Andres Rios replied 15 years, 1 month ago 1 Member · 0 Replies
  • 0 Replies
