Activity › Forums › Apple Final Cut Pro Legacy › Subclip renders revert to a different clip
  • Subclip renders revert to a different clip
    Posted by Jim Courtney on June 24, 2008 at 6:30 pm
    A funny thing is happening now, something I haven’t seen in the past. When I add a subclip in the timeline, double-click on it in the timeline to make sure the in and out points are fine, plays back in the viewer and timeline OK, and have the green render bar above it, I am OK. But when I render it, it isn’t what I have in the viewer(different in and out points, or different clip from the master clip-this happens on two different clips) Here is the strange part: once rendered, I click on the rendered clip in the timeline so I can see it in the viewer, the correct clip(pre-render) shows up! I can’t get the two correct clips to render(out of 144 clips) for some strange reason.
    Anyone else have this situation?
    Jim
    MAC G5 Quad-Core,,OS 10.4.11 Final Cut Pro 6.0.3
    Jim Courtney replied 18 years, 3 months ago 1 Member · 0 Replies
  • 0 Replies
