Activity Forums Maxon Cinema 4D Sub Frame Motion Blur
  • Sub Frame Motion Blur
    Posted by Richard Windsor on February 2, 2014 at 8:53 pm
    I was wondering if there was any way too speed up rendering when using sub frame motion blur. It adds so much time to my renders and I understand why but was just wondering if there are any tricks to get the same look without the longer render times. If there is none I understand. Just thought I would ask.
    Richard Windsor replied 12 years, 6 months ago 2 Members · 2 Replies
  • Adam Trachtenberg
    February 2, 2014 at 9:10 pm
    One thing you can do is disable anti-aliasing, because subframe motion blur does its own kind of AA.
    You can also try using vector motion blur instead of subframe.
    Personally I usually render without motion blur and then add it in post using Realsmart Motion Blur.
  • Richard Windsor
    February 3, 2014 at 12:14 pm
    I will give those options a try.
