Activity › Forums › Apple Final Cut Pro Legacy › Sub-frame editing in timeline?
  • Sub-frame editing in timeline?
    Posted by Jason Brown on November 5, 2010 at 7:02 pm
    Hey Guys,
    If I take an audio clip into the viewer, I can hold down shift and move through the clip what I could call “subframe”.
    How do I do this in the timeline?
    If I load the clip into the viewer from the timeline, I can do the same and then set a new in-point and it adjusts appropriately in the timeline, but I can’t figure out how to move in the timeline with the same “subframe” navigation.
    -Jason
    Michael Gissing replied 15 years, 11 months ago 4 Members · 5 Replies
  • Jerry Hofmann
    November 5, 2010 at 7:36 pm
    The software won’t allow for this. Hey double click, adjust in viewer… it’s not that much of a chore… It’s the way it’s designed to be done.
    Jerry
    Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski. My Blog: https://blogs.creativecow.net/Jerry-Hofmann
    DVD:https://store.creativecow.net/p/81/jerry_hofmanns_final_cut_system_setup
    8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO2 with MAX Cinema Displays
  • Jason Brown
    November 5, 2010 at 8:05 pm
    Thanks for the clarification Jerry, no worries on having to double click…I was just wondering if there was a way…didn’t figure there was since we have to work within the structure of “frame-by-frame” editing.
  • Jeremy Garchow
    November 5, 2010 at 8:52 pm
    [Jason Brown] “didn’t figure there was since we have to work within the structure of “frame-by-frame” editing.”
    That’d be pretty impossible since there’s only 24 or 60 or however you shot, frames per second.
    Audio, on the other hand, has 48,000 samples per second give or take. That’s a lot more instances than 24 or 60. 😉
    Jeremy
  • Jerry Hofmann
    November 5, 2010 at 8:53 pm
    Hey no worries, and you are always welcome… there just isn’t another way.
    Jerry
  • Michael Gissing
    November 5, 2010 at 11:28 pm
    Most editors I work with leave the sub frame stuff to us in audio post. DAWs have sample accurate editing. @ 24 frames there are 2,000 edit point in each frame on a DAW so mucking around in FCP is a waste of time. Also the OMF process from FCP will likely place the edit on a frame boundary anyway regardless of what you do.
