Activity › Forums › Adobe After Effects › stupid question, but how do you flip flop?
  • Alpay Kasal
    June 6, 2005 at 12:17 am
    Not sure if I’m understanding exactly what you need, but you can scale to negative values.
    Select the layer you wish to flip, Hit S to rollout the Scale attribute, unlock “constrain proportions” thingy (next to the 100,100 values) if you intend to only flip vertically or horizontally. Then pop in a value of -100 where appropriate.
    hope that helps.
    Alpay Kasal
    Artist/Engineer
    https://www.NYCRenderfarm.com
  • Steve Roberts
    June 6, 2005 at 12:30 am
    Or … if you want to flop the image horizontally, but still be able to scale it up and down easily, flop it first by entering a scale width of -100 under effect>distort>transform.
    (or enter -100 for height for a vertical flop)
    Then you can scale normally.
    Steve
