Activity › Forums › Blackmagic Design › Stupid question
Stupid question
Posted by Margus Voll on January 17, 2007 at 1:49 pmHi.
Is there memory limit with Mac Pro as on PC 2 or 3 gigs when usin BM drivers.
Margus
Jud Archer replied 19 years, 8 months ago 3 Members · 4 Replies -
Mike Procunier
January 17, 2007 at 4:26 pmYes it’s limited to 3GB. Since the MacPros require matched pairs of RAM your limited to two 1GB sticks. (I’m not sure if you can get 512MB sticks for MacPro)
Margus Voll
January 17, 2007 at 4:30 pmBut if i want to use meny apps at the same time then i’m in trouble ?
I think it is possible to get 1 gigs with 512 stics (2*512).
So it is possible to get 6 x 512 in theory.Do you know if there will be newer version of driver which corrects this problem ?
Margus
Mike Procunier
January 17, 2007 at 5:41 pmThey say they will support more than 3GB in a future release of Decklink. When that is I’m not sure.
Jud Archer
January 17, 2007 at 7:56 pmDoes this apply to the HD cards as well or is it limited to the Standard Def cards?
Jud Archer
Systems Integrator
