Activity Forums Adobe After Effects stupid mask question
  • stupid mask question
    Posted by Zander on March 18, 2006 at 11:34 pm
    ok ive got a problem, ive created a hallow “block” octagon, using 2 masks, unfortunatly right now im using 2 layers, scaled the inside mask to 80 percent of the original, i need to copy the mask and apply it for a morph to a different layer, the problem as you all probably know, is if a mask is creted in another layer, and then the layer is duplicated and scaled, there is no way to copy this “new” mask shape, as the shap has not changed relative to the layer, just teh scale of the layer
    so my question is this:
    How can i either reveal the mask through all layers so i can just click my mask tool 8 times and be done with it, and have my new mask. or how do i scale this mask, or copy this mask into the new layer
    thanks
    Aaron Zander-Student edditor
    If it’s out there and it does somethign to something,
    teach me how to use it
    Powerbook g4 1.5 GHz (it might not be big, but i can take it on set
    fcp 5, ae 6.5pro adobe cs2
    Roland R. kahlenberg replied 20 years, 5 months ago 2 Members · 1 Reply
  • Roland R. kahlenberg
    March 19, 2006 at 6:42 pm
    I’m not sure if I understand your issue correctly but perhaps the following will help you to sort out the issue.
    Before you copy a mask from one layer (Layer A) to another layer (Layer B), that already has a mask, you should have a keyframe for maskshape or Layer B. Then copy the mask from Layer A. Move the Timeline Indicator to a new point in time. Goto the Layer Window for Layer B and select Target->Mask 1 before pasting the mask. This will create a new keyframe for maskshape for Layer B.
    HTH
    RoRK
    broadcastGEMs
    customizable animated backdrops with Adobe After Effects project files
