Stumped on text expression
So let me try and explain my problem clearly.
I have a number value that’s counting up past 25,000.
The value is controlled by a slider that has a Math.floor command on it to keep the value in integer format.
The problem is that I need to have the comma appear when the values are in the thousands. Right now the numbers are just in whole number formats.
Does this make any sense to anyone? Hopefully I’ve expained myself clearly enough.
Thanks-
Aaron
