Activity › Forums › VEGAS Pro › Stumped on muting audio of two different clips on same timeline
  • Stumped on muting audio of two different clips on same timeline
    Posted by Jeff Mcguire on March 27, 2009 at 4:07 am
    Wow This really stumped me
    I have two clips with corresponding audio. The latter one needs it audio muted because I added synched audio. When I mute, the whole audio bus gets muted. Nowhere can I mute a selected track.
    Help
    Jeff
    Jeff
    Jeff Mcguire replied 17 years, 6 months ago 4 Members · 6 Replies
  • Kert
    March 27, 2009 at 5:13 am
    On the left of the track near this (!) there is an audio mute botton. Click and will mute the track. JK
  • Douglas Spotted eagle
    March 27, 2009 at 8:57 am
    you can mute an individual clip by click/dragging at the top of the clip/event and pulling the gain all the way down.
    you can mute on a track using automation, simply hitting the mute button on the track (Z) while playing back with automation enabled.
    You can mute using a volume envelope and manually inputting a mute/envelope.
    Douglas Spotted Eagle
    VASST
    Certified Sony Vegas Trainer
    Aerial Camera/Instructor
  • Jeff Mcguire
    March 27, 2009 at 10:47 am
    Thanks Douglas!
    Your first answer did the trick!
    Second part: Didn’t understand Track Z or Automation
    Third part: I tried volume envelope but it kept affecting the entire audio bus, not my individual track.
    Thanks for taking the time to reply.
    Jeff
    Jeff
  • Jeff Mcguire
    March 27, 2009 at 10:57 am
    Douglas
    Along those same lines, the audio track I added needs to lock and move with the video I synced it to. I assume there’s an easy way to do this? Thanks!
    Jeff
    Jeff
  • Terry Esslinger
    April 1, 2009 at 5:52 pm
    Since no one has popped up on this one thought I might jump in. Select the audio event and the video event that you want to move together and type G (Group) As long as you do not have ‘ignore event grouping’ selected they will now operate as a group.
    BTW did you get your ‘text over video problem’ solved?
  • Jeff Mcguire
    April 1, 2009 at 6:32 pm
    wow – thanks!
    one small silver lining today – I’ll take it!!!
    Jeff
    Jeff
