Stuck with the RAW workflow….. !!!
Hey guys..
I really need some help regarding the 4k edit since this is my first time editing raw. I have shot a film on BM URSA mini 4.6k pro RAW @ 4k, 4:1 compression. I have a confusion between 2 approaches ….
1) Should I use the Round-trip approach of Resolve-PPro-XML-PPro-Resolve?
Now, I need to do lots of effects work in premiere like stabilization, match move, rotoscopy, camera digital zoom/pan and also need to add external elements like Wall clock footage shot on green BG to be inserted in the matchmoved scene of Wall. Now can I get all this stuff back in the Resolve via XML? If it’s possible , what is the best approach?2) Should I just export a high res file to premiere?
Since the Color correction is a not a major requirement I can make do with the LUTs that I have and render the final film in Premiere itself. I’ll use Resolve only to transcode so that Premiere can “read” Raw footage(Tried importing a RAW 4:1 file directly in premiere and it took hell of a time loading it, cancelled in between before it loaded).
In this approach what is the best format to use? I tried DNxHR 444 (Render at source resolution 4k) which gave me a full frame video , but at double the size !! Should I use this format?Your suggestions will help a great deal.
Thanks a ton
Cheers
Nik
