Activity Forums Adobe After Effects stroke>generate : disappears with collapse transform?
  • stroke>generate : disappears with collapse transform?
    Posted by Mac Lanphere on June 21, 2012 at 3:02 am
    hi everybody
    I have a stroke>generate effect applied to a 3D layer (solid) that works fine (albeit fuzzy) until I hit collapse transform–and then it disappears from view?
    any ideas?
    many thanks
    ML
    Mac Lanphere replied 14 years, 3 months ago 2 Members · 2 Replies
  • Walter Soyka
    June 21, 2012 at 8:17 pm
    The default rendering order in After Effects is masks, effects, transformations, layer styles.
    When you engage continuous rasterization/collapse transformations, you change that layer to masks, then transformations, then effects.
    If you need to avoid continuous rasterization/collapse transformations but don’t want that nasty blur, resize the solid itself and adjust the effect.
    Walter Soyka
  • Mac Lanphere
    June 22, 2012 at 2:48 pm
    thanks very much for that– but I was mistaken, the layer I’ve applied the stroke effect to is a path (form illustrator) and not a solid layer.
    would it still make sense to increase the size, and reapply the stroke? even though it’s a vector asset to begin with? or, is there another way to work with vector paths…
    ML
