Stroke Effect Reveal Image on Multiple Layers Not Working
I can’t find a post that deals with this problem which surpirses me but maybe I’m just not looking hard enough.
Here’s my problem: I’m applying a stroke effect to reveal image on multiple layers, but it only seems to work on the first layer I apply it to. These layers have A LOT of masks in them but that doesn’t seem to matter, it works fine the first time I try it (no matter which layer) but then it just sits there on the next layer.
I have noticed that the second time I try it, the path pull down box in the effect panel will only let me select ‘none’ or the last mask in the list, I can’t select ‘mask 1’ or anything in-between, this is only in the effect panel. In the timeline I can select whatever I want. I don’t know if this matters because I’m checking the ‘All Masks’ box but it does seem to be a glitch.
I’ve tried precomposing each layer, but that doesn’t help.
What am I doing wrong?
Surly I’m allowed to use this effect on more than one layer, right?Thanks.
