Activity Forums Broadcasting stripes on playback of DVCPRO tapes
  • Mark Suszko
    April 26, 2010 at 2:27 pm
    DVCPro HD and DVCPRO 50 are not going to play in a DVCPro25 deck.
    If your deck is a more advanced one that can play the HD and 50 meg flavors of DVC Pro, then I think all you need to do is go into the menu settings and change it to the correct format. Though a higher end DVC pro deck should be auto-detecting the format and adjusting to play it. You can also set a menu pref for that, I think.
    What model deck are you using?
  • Micah Mcdowell
    April 26, 2010 at 5:03 pm
    The AJ-D230H is definitely standard-def DVCPro25 only; no DVCPRO50 or HD support if that’s the issue.
    If the tapes do indeed contain plain ol’ DVCPro25 footage, your deck have dirty heads or need repair.
