Activity Forums Adobe After Effects string of objects to follow a psuedo Bezier
  • string of objects to follow a psuedo Bezier
    Posted by Juan Hernandez on October 31, 2011 at 7:30 pm
    Hi all,
    I am having a touch of a hard time figuring out Dan’s awesome tutorial:
    https://www.motionscript.com/expressions-lab-ae65/bezier.html
    I am trying to pull this off only the test scenes of the solids are not following nulls as I imagined. Has anyone did this before where they might want to share their AE scene for me dissect?
    What I did was made a solid and under the position, I pasted the expressions Dan shared.
    Nothing happened as mentioned in the tutorial and no immediate gratification was established once I pasted the expression as instructed.
    Thanks for any who help out.
    -J.
    Brian Charles replied 14 years, 10 months ago 3 Members · 4 Replies
  • Juan Hernandez
    October 31, 2011 at 8:32 pm
    Okay I think I got it…but I’d like to get help with the slider bit of the tutorial…THIS IS SUCH A COOL SETUP!
    THank you DAN!
    And thanks for those that help in response.
    J.
  • Juan Hernandez
    October 31, 2011 at 9:42 pm
    THank you DAN!
    And thanks for those that help.
  • Dan Ebberts
    October 31, 2011 at 11:10 pm
    What do you need help with?
    Dan
  • Brian Charles
    October 31, 2011 at 11:12 pm
    After adding the slider expression control to Null 1 the modification the script should read:
    N1 = thisComp.layer(“Null 1”);
    N2 = thisComp.layer(“Null 2”);
    N3 = thisComp.layer(“Null 3”);
    N4 = thisComp.layer(“Null 4”);
    p0 = N1.position;
    p1 = N2.toWorld(N2.anchorPoint);
    p2 = N3.toWorld(N3.anchorPoint);
    p3 = N4.position;
    c = 3*(p1 – p0);
    b = 3*(p2 – p1) – c;
    a = p3 – p0 – c – b;
    t0 = index/(thisComp.numLayers – 3);
    s = N1.effect(“Slider Control”).param(“Slider”);
    if(s < 0){
    s += 1;
    t = t0*s;
    }else{
    t = s + t0 – s*t0;
    }((a*t +b )*t + c)*t + p0
