stretching an image inward/shrinking hub on a DVD
I have an old image that I’ve been using to print one of our DVDs and our new batch of DVDs has a larger print surface that goes further into the hub than the last batch. Problem is that the only image we have is blank in the center to allow for the hub and it doesn’t print all the way to the center on these new DVDs.
I’m thinking there has to be a way in Photoshop that I can “stretch” this image inward into the hub so that it covers the whole surface.
I’ve tried selecting the hub, then select inverse and free transform but it won’t give me controls in the center circle to pull it inward. It just allows me to grab the controls on the outside of the whole DVD which doesn’t help.
Does anybody know of a way I can get this done without having to try to use the cloning tool in the center?(the image is too intricate to make it look good this way)
Does this even make sense?
