Activity Forums Adobe Illustrator Streamline 4 Equivalent How-to in Illustrator CS2 Question
  • Streamline 4 Equivalent How-to in Illustrator CS2 Question
    Posted by Rufus Napkin on July 16, 2006 at 10:20 pm
    What is the best way to convert a PSD image into Vector in Illustrator CS2? Does the method used by Ill. CS2 produce better results than Streamline?
    Rufus Napkin replied 20 years, 2 months ago 2 Members · 2 Replies
  • Mike Gondek
    July 17, 2006 at 8:35 pm
    place an image
    object >> live trace >> make & expand
    if you want to tweak the results:
    undo
  • Rufus Napkin
    July 18, 2006 at 11:14 pm
    Thanks Mike. I know I should have figured it out, it was relatively easy, I just haven’t worked with CS2 before.
    This option produces way better results than Streamline.
