Activity Forums Adobe After Effects streaming water/ink/paint…
  • streaming water/ink/paint…
    Posted by Berrege on May 25, 2007 at 5:11 am
    hey!
    i got a question! is there a way to get a streaming ink-effect, a bit like this one:
    https://youtube.com/watch?v=4Y2JfC2zxrM
    but mine is streaming on a ‘flat surface’ (so it’s not dripping from the wall or so)
    i know this example is probably just shot with a real camera (it looks like that), but the problem is that i really need to have control over the stream, since it has to go in particular directions. the write-on effect wasn’t working quite right, since it can only do 50 pixels (or so) and my ‘stream’ is a lot wider than that (it’s actually designed in illustrator)… so, anyone who can help me?
    thanks!
    Darby Edelen replied 19 years, 4 months ago 2 Members · 1 Reply
  • Darby Edelen
    May 31, 2007 at 1:52 am
    Well, you could try to roll your own with a stroke effect, maybe a turbulent displace and some other detailing effects. Or you could try using CC Glue Gun, which is similar to write on only it has a naturally liquified look to it and you can animate properties to make the stream wiggle.
    Darby Edelen
    DVD Menu Artist
    Left Coast Digital
    Aptos, CA
