Activity Forums Apple Final Cut Pro Strategy for Syncing for Feature in X
  • Strategy for Syncing for Feature in X
    Posted by David Mcclellan on November 16, 2014 at 7:41 pm
    Just wondering what your strategy is for hundreds of clips a la feature film sync and prep. Been used to doing it in 7 with plural eyes. For this new feature I am posting I plan to organize each scene into separate folders. Label each vid clip with corresponding matching sound clip(s) – our sound guy did not label anything on his recorder so – fun times there… Then sync in plural eyes – export XML for X. Open XML in X and check sync in timeline – shut off all video scratch audio tracks – trim to action in timeline and finally create compound clips of each take. Then reorganize bins in X and create new project with only the new compound clips for each respective scene and then add take metadata to prep for edit.
    Is there a better way? What is your strategy for this process.
    -DM
    Oliver Peters replied 11 years, 9 months ago 6 Members · 18 Replies
  • 18 Replies
  • Oliver Peters
    November 16, 2014 at 8:54 pm
  • David Mcclellan
    November 16, 2014 at 9:16 pm
    Yes – there is no common TC here.
  • Oliver Peters
    November 16, 2014 at 9:17 pm
    What about just using the built in synching in X?
    Oliver
    Orlando, FL
    http://www.oliverpeters.com
  • David Mcclellan
    November 16, 2014 at 9:22 pm
    Yeah I may just do that. Organize everything in scene folders and sync in X.
  • Craig Alan
    November 16, 2014 at 10:00 pm
    I found x does a good job. I’d try it first and only consider something else if it falls short.
    Mac Pro, macbook pro, Imacs (i7); Canon 5D Mark III/70D, Panasonic AG-HPX170/AG-HPX250P, Canon HV40, Sony Z7U/VX2000/PD170; FCP 6 certified; FCP X write professionally for a variety of media; teach video production in L.A.
  • David Mcclellan
    November 17, 2014 at 12:12 am
    Yeah – I’ll give X a go – I’m still organizing all of the sound files and setting up the folder structures etc… I was just wondering what other people are doing for syncing on feature length stuff with lots of footage and no TC but this seems to be the way to go.
  • Craig Alan
    November 17, 2014 at 12:28 am
    Please post your experience. I am in early stages of a longer format film using one of three cams for sound and will need to sync TB’s of footage. No given run will last more than 70 min but I have no experience with this amount of media.
  • Oliver Peters
    November 17, 2014 at 12:36 am
    [David McClellan] “I was just wondering what other people are doing for syncing on feature length stuff with lots of footage and no TC”
    I had tried an alternate method on a short. There I used the “open in timeline” function to embed audio into each master clip – synced by slate. I would not recommend this. It worked fine during the edit, but I had all sorts of trouble when passing audio over to my sound designer/mixer.
    FWIW, PluralEyes also has the capability to generate new media files with the picture and clean audio merged into new clips.
    – Oliver
    Orlando, FL
  • David Mcclellan
    November 17, 2014 at 12:45 am
    Yeah I tried that export new media in PE and on certain clips I noticed some color shifts in the skin tones on the exported files. I’ll test it further just to be sure but this would be the simplest way for sure. Synch in PE then export a new file with audio replaced.
  • Bill Davis
    November 17, 2014 at 6:05 am
    David,
    It sounds overly complicated to me. X’s synchronized clip workflow is pretty darn accurate if you have a decent scratch track on you’re camera files that allow X to match the second system audio. For me the key is that as soon as you get each synchronized clip created, Immediately reject both the original video and audio source files and work with “Hide Rejected” enabled. That should yeild exactly what it appears you want (hide all but one clip of each take with good audio) without all the export/import hassle. It’s certainly worth a test, anyway. As to the missing audio clip labels, dig into the sound clip metadata in the inspector by trying one of the more comprehensive views that go beyond the General view – and you might find a sort field that can order your sound takes to match the video. If so, use the X custom file renaming functions to match them to the video file names. it’s will make syncing stuff a whole lot easier.
    X has really good tools in both these areas.
    Finally, if you run into serious problems, let me know. I’m sure Sam Mestman or Mike Matzdorff in LA would be happy to trade an email or two with you to get you past any serious hurdles. Happy editing.
    Know someone who teaches video editing in elementary school, high school or college? Tell them to check out http://www.StartEditingNow.com – video editing curriculum complete with licensed practice content.
