Activity Forums Apple Final Cut Pro Legacy Strangest audio export problem
  • Strangest audio export problem
    Posted by Michael Black on April 20, 2006 at 6:59 pm
    This has been happening off and on lately and so far, I can’t figure out why.
    I do most of my work using the Kona2 card, working in uncompressed 10-bit HD with the black magic codec. Lately, however, I’ve been having problems exporting .aif files from HD projects (possibly SD; still experimenting). Even if I’m exporting a quicktime movie with the audio uncompressed, it comes out horribly distorted. I would compare it to the sound a dentist drill makes inside your head. It’s awful.
    any clues as to why this may be happening? I’ve trashed prefs.
    Ben Holmes replied 20 years, 4 months ago 2 Members · 4 Replies
  • Michael Black
    April 20, 2006 at 7:18 pm
    I noticed that this problem only seems to happen when I have my Easy Setup set to one of the HD Kona settings. I switched over to an SD setting and exported and it worked fine. So… if anyone else has this problem… give that a try.
  • Ben Holmes
    April 20, 2006 at 8:02 pm
    Could the problem be to do with playback rather than the file? Have you tried putting the exported QT into a new Kona HD project to see if it’s a playback codec issue?
    As a Kona 2 user, I’d like to know how you get on – keep us posted (and give us your system details).
    Ben
    Editec Broadcast Editing Ltd
    EVS and FCP specialists
    Current Mac systems All Dual 2.7Ghz with Kona 2 and Digital Voodoo cards, 6Gb Ram, Sapphire, SCSI320 Medea and Huge Arrays.
    FCP projects include Sky TV coverage of the Ryder Cup and US Open Golf – Live OB specialists. Edit/slomo vehicle.
    http://www.editec.co.uk
  • Michael Black
    April 20, 2006 at 8:14 pm
    Playing back the audio that’s imported is fine. It’s when I export a quicktime (for internet posting or whatnot) the audio comes out horribly glitched. I don’t think the board is at fault, but something to do with the settings in FCP when the board is in use.
    Bear in mind, I’m also still running FCP 4.6 and quicktime whatever-came-before-7.
  • Ben Holmes
    April 20, 2006 at 9:58 pm
    Can I suggest (if you havn’t already) that you post in the Kona forum – perhaps the issue you have is version-related, possibly the Kona drivers, or FCP or QT (or combination of each/all three).
    I have found Kona/AJA customer support excellent in the past, and worth a contact.
    Ben
