Activity › Forums › Boris FX Particle Illusion › Strange thing
  • Posted by Mats Lundgren on October 6, 2007 at 1:42 pm
    Hi, I have problem, I have an uncompressen HD 1440/1080 avi file, but when I try to get it in to Particle illusion, the right side of the video becomes the left side of video, is this a bug ?, it works as supposed in my editing app, and it works ok in wmp
    Mats Lundgren replied 18 years, 12 months ago 2 Members · 4 Replies
  • Elvis Deane
    October 6, 2007 at 3:46 pm
    Do you have the same problems with standard definition uncompressed clips or is it only with HD? I’d suggest using either the Lagarith or HuffyUV codecs and seeing if you get the same results. Both are lossless, so they’re fine to use for production.
    Elvis Deane!
    The Apprentice Magician’s Guide to particleIllusion
    Wilbur of Wumbaberry
  • Mats Lundgren
    October 6, 2007 at 4:43 pm
    I don
  • Elvis Deane
    October 7, 2007 at 1:18 am
    Just Google the word Lagarith and it should come up as the first result, installation instructions should be on that stage.
    If you want to save some hard disk space, you can render out PNGs rather than TGA. They’re lossless and generally much smaller.
  • Mats Lundgren
    October 7, 2007 at 8:08 am
    Thanks for the tip, I found the codecs, I know I could google, but I don
