Strange Pre Composition Bug?
I am having a pretty strange problem which have occured two times, and I have no idea why it is happening.
I will show with screenshots:As you can see here, I have a composition with a sniper scope, and the rest of the comp is empty:
https://gyazo.com/939041de4ef3f2b7d1a697810a084a6eHere is my main comp with the sniper scopes on:
https://gyazo.com/6af0976d56e20ca4f1c97575d6b5c74eBut when there should be nothing in the comp, this is what I see:
https://gyazo.com/7a5cf79bec50f6b86e0a84ccc9ca6e69
This is a screenshot from another project, which I not have imported into this one.This only occur when the project is set to “Full”
https://gyazo.com/553d28fd44d6653e31580ef26ba9fbd5I have no idea why this would be showing, but it happened another time too. The other time it happened I also had a transparent composition, but it showed a screenshot from another project I not was using. The picture will show in the rendering too…
Do anyone have any clue why this is happening?
