Activity Forums Adobe Premiere Pro strange mpeg1 encoding problem in PPro2
  • strange mpeg1 encoding problem in PPro2
    Posted by John Baum on February 22, 2006 at 3:27 pm
    Here’s a screengrab of the problem
    https://www.flickr.com/photos/51881644@N00/?saved=1
    This problem only occurs on footage that I captured from tape(beta sp) that was output from our Avid Adrenalin system. Anything rendered on my machine or captured from tape that was originally output from my ppro system are fine.
    If I render the timeline to another format, bring it back to ppro and render to mpeg1 it still occurs.
    If I render the same footage to mpeg1 using cleaner 1.5, the problem does NOT occur.
    I’ve tried about a dozen combinations of settings in ppro all with the same result.
    John Baum replied 20 years, 6 months ago 2 Members · 2 Replies
  • Jeff Bellune
    February 22, 2006 at 4:02 pm
    If you are exporting from AA as a QT reference movie, try a self-contained quicktime. You said you tried “other formats”, but you didn’t specifically mention QT.
    PS – I estimate your chance of success using my suggestion at about 5% – 10%.
    If you haven’t done so already, I recommend spending as much time tweaking project and export settings in Avid as you have in Premiere.
    -Jeff
  • John Baum
    February 22, 2006 at 4:11 pm
    What Avid settings would make a difference?
    The avid stuff behaves fine on the ppro2 timeline, and when exporting to other formats besides mpeg1.
    I am going to have the avid operator send me a rendered file so as to bypass the tape capture and see what happens.
